What should I do?
I will be driving my red svx to TN for my girlfriend to drive for the summer and at school for the fall. I am doing full brakes right now (new d+s rotors, pads, ss lines), the belts are new (15k on them or so) timing belt was done at 70k (118k now), just did an oil change, all other fluids are good ( a while back I did mistakenly put ps fluid in the ps pump though, not atf. Only maybe 1/3 a qt total) since the car will be in a hotter climate should I flush the coolant? I will be installing a tranny cooler when I go down in July and August. Are there any other recommendations?
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
I wouldn't flush the cooling system; just check the condition of the hoses and radiator cap, and top-off the reservoir as needed. If it's been years since the coolant was changed and you expect to be doing lots of urban, stop-and-go driving, just do a 50/50 drain and refill.
Using "power steering fluid" instead of ATF won't hurt anything. dcb |
You seem to have it well sussed, Sicksubie.
Cambelt would need changed again at 130K or so, but is probably OK. I would not worry too much about the steering fluid. It will mix and be OK. If you do worry, then use a turkey baster to empty the reservoir, and fill up with ATF as instructions to level. For peace of mind, service routine does recommend a flush and replace of coolant, and I would do that in your case. While at that, inspect the hoses and the top of radiator for leaks, you know that is a potential trouble area. The other thing I would check in your shoes is the fluid levels in the front and rear differentials. If these are low for any reason [not checked for years, maybe?] you run the risk of heating a bearing. Better checked. If you want to be bombproof and anal, you could strip the hubs and repack the wheel bearings with the proper grease. This is actually recommended to do after bearing failure, and might save a bearing going bad on you. The only other wise thing I would bother with are the rubber boots, two on the front axle CV joints, and two on the steering rack. Check them for holes, tears and leaks. Replace as necessary. If you have all that done, it should buy peace of mind. Joe
Black Betty [Bam a Lam!] '93 UK spec, still languishing Betty Jersey Girl Silver '92 UK [Channel Isles] 40K Jersey Girl @ Mersea Candy Purple Honda Blackbird Plum Dangerous White X2 RVR Mitsubishi 1800GDI. Vantastic 40,000 miles Jersey Girl Last edited by svxistentialist; 05-02-2007 at 12:30 PM. |
CV boots are fine, radiator is strong with new silicone hoses, I think I have everything covered.
Wheel bearings are the only thing that I am truly concerned about.
How's the AC? it's pretty warm downt here, she might not be to happy if she's driving around in 100 degree heat with 4/60 ac.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
Make SURE you have that tranny cooler installed before the Dragon Meet, as the Dragon will definetly heat up the tranny, esp. of it has the stock 3.54 gearing....
Any of the hoses should be checked to make sure they are not hard and ready to leak.
Hey, perhaps you could get a lot of those bumpers that they tie on boats for when they hit the dock. I bet she'd just love that. What are you going to do when you call her? I can almost hear the conversation now, 'yea yea yea, you're fine, schools good, now, rev the engine for me again...' Maybe you could get a gps system installed so that you can track to monitor her location and speeds. The really bad thing about the svx is that once she gets her hands on it you might as well write it off because she's not going to give it back unless you get her one of her own. Best of luck to you. |
