Old 04-24-2007, 08:35 PM
OrIoN's Avatar
OrIoN OrIoN is offline
Clunking from rear while accelerating...
I'm guessing it's the rear diff. However, I haven't learned how the AWD functions yet. My background is with Quattro, this is my first Subaru...
So, if it's the rear diff., I need to be pointed in the direction of a cost effective replacement possibly re-man used or good used part...
OrIoN's harem is Pleiades
'96 SVX LSi AWD
'93 Audi S4 20v Turbo 5cyl Silver/ Platnium
Euro converted, EO Sports Suspension, RoH Reflex, Denon ICE
Euro Converted, ABT/ Bilstein, MTM stage 3+ (340hp), ABT exhaust, Euro S6+ brakes, Gloss Black trim, Alpine/ ADS ICE
'93 Audi S4 20v Turbo 5cyl Black/ Ecru
MTM Stage II, H&R 29921/ Koni adj., RS4 wheels, Boxster S Brembos on 2-piece Colemans, Old Skool Lanzar ICE
Old 04-24-2007, 08:51 PM
It could be a bad bushing on the rear diff, or transmission. It could also be a bad driveshaft or center carrier.
Can we get a better description of the noise and when it happens??
If it is the diff, I have one for sale, send me a PM.
Nomake Wan's Avatar
Retired
Try putting the fuse into the FWD slot in the fuse box under the hood and see if that solves the "clunking from the rear" problem. If it does, then you're right and it's the rear diff. Cost-effective test.
Old 04-24-2007, 09:02 PM
OrIoN's Avatar
Interesting... can I just pull a fuse for AWD and move it to a FWD location?
'96 SVX LSi AWD
Old 04-24-2007, 09:07 PM
There's no AWD fuse but there are spare fuses in the underhood fuse box. The lid of the box is also labeled to let you know where to put the fuse for Front Wheel Drive.
But... Your rear diff and the rest of the driveline are still connected to the wheels, they will still spin when you are in FWD mode. Just keep this in mind when you do your diagnostics.
Old 04-25-2007, 05:51 AM
JaySVX's Avatar
JaySVX JaySVX is offline
You can insert a fuse into the FWD slot under the hood for "limp" mode, to make it home, and such. Did you check your tranny mount? Mine is gone, which causes the thump in mine sometimes when shifting from drive to reverse, or park.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 04-25-2007, 07:15 AM
OrIoN's Avatar
the noise is a repeated clunk from the rear while on the gas from a stop or roll. It subsides once I taper off the gas...
'96 SVX LSi AWD
Old 04-25-2007, 07:59 AM
Once per wheel rotation or ~3 times per rotation??
Old 04-25-2007, 08:07 AM
OrIoN's Avatar
I think 3... but I will drive it again after work today and try to listen for that answer...
'96 SVX LSi AWD
Old 04-25-2007, 08:13 AM
sounds like binding to me...
Old 04-25-2007, 08:56 AM
OrIoN's Avatar
so dinding can happen while driving straight, not just turning?
'96 SVX LSi AWD
Old 04-25-2007, 09:30 AM
absolutley... You load up the drivetrain with torque around a turn... If you are driving straight it has no release expect the tires and your transfer clutches... In this case it sounds like your transfer clutches... much like my teal does on occasion. BUT I am not sure because I have not heard it myself... Have you see the power ligth blinking at all on start up?
Old 04-25-2007, 09:39 AM
OrIoN's Avatar
I have not seen the power light... but I'm not sure all dash lights work nor really paid attention to start up lights... I only started it once really
'96 SVX LSi AWD
Old 04-30-2007, 07:18 AM
OrIoN's Avatar
Drove a little bit this weekend. It does cluck 3 times per rotation, and will go away with the FWD fuse in... rear diff?
'96 SVX LSi AWD
Old 04-30-2007, 08:43 AM
JaySVX's Avatar
Sounds like binding. It's engaging all the tires at the same time and same speed, so turns or even strait, it'll do that, because the rotational speeds will never be exactly perfect for all tires.
