Old 04-24-2002, 08:55 AM
Invisible avatar
Wink Re: Align it
Originally posted by svxistentialist
Ron.
The SVX does not show heavy pulling in my experience. I had two fast Renaults, fwd, and if the rear wheels were down a few pounds, the steering pulled. You could drive the SVX with one nearly flat and not notice the steering pulling. So you might have drag on your tyres, be wearing them badly through mis-alignment, and not see much difference to drive.
Play it by the book is my rule.
I guess my concern, Joe, is having some stranger fondling the nether regions of my car with his big tool & finding a way to tell me that I need to replace a bunch'a tie rods & axels just to conform to "the book", when no negatory symptoms seem to exist in the first place. Hell, I wouldn't have high blood pressure if I hadn't gone to a doc 10 years ago & had it checked. Now I'm a captive to all the expensive medications he can get me to swallow. We can't even drop dead in peace anymore.
Ron (ranting).
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 04-24-2002, 09:50 AM
kuoh kuoh is offline
I assume that you're reading the MAX tire pressure warning on the tire itself and not what it says in the manual or on the door plate. The recommended pressure is 33f/29r, but I noticed excessive shoulder wear with the original tires, so I started to fill it up to 36 all around. I also have to rotate the tires a lot less this way. 44 is very high if you're filling it cold, and even if you're not.
KuoH
Originally posted by BoominSVX
Is it just the heavy car that steers itself, or should I lower my psi from the recommended 44 psi down to 35 or so?
Old 04-24-2002, 12:56 PM
BoominSVX's Avatar
BoominSVX BoominSVX is offline
I hate stupid people!
Send a message via AIM to BoominSVX
Good call, I knew it seemed a little high. I guess I gotta crack out the tire pressure guage and see what we can do here.
Old 04-24-2002, 01:09 PM
Green95hoe
I told you 44 was unrealistic.. And you laugh when I run 15 Pounds on the street and 5 on the beach!!!
