Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 03-02-2007, 05:14 PM
min's Avatar
min min is offline
95 SVX L - New owner
Send a message via AIM to min
butterfly hinges
ok. so got the svx running great. was going to sell, but now my son wants butterfly hinged doors. has anyone ever done this??
Old 03-02-2007, 06:07 PM
Mr.Pwrlite's Avatar
Mr.Pwrlite Mr.Pwrlite is offline
Butterfly, Lamborgini style, whatever you want to call it... I done it, but its not easy or cheap. Theres no kit out there for the SVX that I know of.
"If it works, tear it apart and find out why!...... "
94 Blue L, 5-speed, converted 4wd, Clear headlights, Angel Eyes, Converted Radiator and fan, White faced guages, Cross-drilled/slotted rotors, Lambo doors ...
Old 03-02-2007, 07:22 PM
min's Avatar
min min is offline
wow
WOW! that is so cool. i can see why my son wants that. expensive, huh?
Old 03-02-2007, 08:06 PM
"Scissor", "vertical" and "lambo" doors are all the same. They pivot forward and up.
"Butterfly" doors are different. They rotate up and over as they move forward. Kind of a mix between the vertical door and the gull-wing.
Butterfly doors can be found on the McLaren F1 and the Saleen S-7
Old 03-02-2007, 08:12 PM
sicksubie's Avatar
pwrlite, what did that cost?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 03-02-2007, 08:38 PM
They look good. Let us know how you did it and what the cost it.
Old 03-03-2007, 12:52 PM
Mr.Pwrlite's Avatar
Well cost of the hinges depends on where you go. The quality of the hinges also depends on where you get them. My kit cost me $1500, and there were still parts that needed to be adapted. I have welding experience so I saved $$ in the additional fabrication.
The whole project lasted 6 days, basically 4 days working on it after work, and 2 weekend days. The critical measurements are taken from the existing door hinge bolt pattern length, meaning the distance from the top bolt hole to the bottom hole in the door and chassis.
The door length and weight is next to be considered, for the position of the lift shock. The shocks that work best in my hinges are 850lbs(trial and error), that's the lift capability.
The funny thing is, if I were to do this again I couldn't guarantee that it would turn out the same..., who knows maybe better All I know is there's a lot of fitting, cutting of steel and sheet metal, grinding, welding, and wires that have to be extended.
It also took much determination. But in the end....
...And yes this conversion is typically called: Lambo doors, Vertical doors(VDC), or Scissor doors. Other conversions have different hinge points that give a different door opening effect.
Good luck to all who try it.
Old 03-03-2007, 01:18 PM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
Guys, this is why I joined a car club where one of the members owns a machine shop... He said he would make me up a kit for his cost... $300!
I am getting them in june. After I get them in I will tell you how they went and maybe I can get you guys a at cost + little over from him... ok?
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 03-03-2007, 01:36 PM
min's Avatar
min min is offline
$300
please let me know how it goes. 300 sounds a lot better than 1500, although i do realize how important doors are.
Old 03-04-2007, 12:52 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
i'm going to be doing this conversion in the summer there is a bit of a how to write up in this fourm somewhere just search for it...
- John
Old 03-04-2007, 06:40 PM
It's Just Eric's Avatar
Missing in action
please, for the love of god, consider that you get what you pay for. I did bodywork on an eclipse that had the most half asses lambo door hinges on it. He had to cut away some of the fender supports, and in the end he got doors that opened out, bounced off the fenders, then went up...On the way down, theyd drop too far and the door would hit the striker...the doors never closed right, not to mention it ripped off the door molding and crappy side skirts he had on the car. A 1500% kit rather than a 300 dollar kit is probly the way to go.
Personally, I think vertical doors look kinda cool... untill you're in a parking garage and have to squeeze out from under your door, or your car flips upsidedown and catches on fire *NWS link, extreamly graphic images*
R.I.P Cool Signature.
Old 03-04-2007, 07:49 PM
sicksubie's Avatar
Personally, I think vertical doors look kinda cool... untill you're in a parking garage, or your car flips upsidedown and catches on fire *NWS link, extreamly graphic images*
Unfortunately this is not the only accident of it's kind...
You could never get me to do this to any car period. What is the point? If your car is going to be competing in shows then fine, but otherwise it is a waste of money and you must be an individual that simply craves attention. If you can't drive a SVX that gets plenty of attention without lambo doors as it is then I don't know what to tell you.
P.S. take the 1500 for the kit and the probably additional 1500 in other body work involved and get cams, an exhaust, Koni/GC suspension, and some decent rims and good tires. You will have a far more impressive car if you do.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 03-04-2007, 08:09 PM
michael's Avatar
michael michael is offline
What Potholes ???
Wanted: Steering Wheel
Old 03-06-2007, 10:14 AM
min's Avatar
min min is offline
nevermind
Ok. Nevermind. All I can see when I look at those pics is my son. NO WAY! He can find better ways to spend his money.
Old 03-06-2007, 03:00 PM
CigarJohnny's Avatar
I never thought of flipping the car on it's roof. I thought it would be cool until I saw those pics. I'll pass.
BTW...did anyone else think the gal talking to the fireman was pretty hot? Hope she wasn't related to the Lambo driver.
-Johnny (it's ok, I know I'm a pig)
