Old 04-13-2002, 07:31 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
SVX Brakes in question
OK, so I'm over helping Brian change the cam cover gasket on his 944 Turbo. We also decide to check the brakes for wear. What I see shocks me!
This car weighs several hundred pounds less than the SVX but it has vented rotors on the REAR that are 1.25 inches in diameter bigger than the FRONTS on our SVX. The pad surface area is at least 75% bigger than the SVX on both fronts and rears.
What am I getting at? This particular model Porsche has the same size tires and rims (225/50-16 and 16x8 rims) as the SVX and yet they can fit much bigger brakes in that space than Subaru did.
Am I missing something (Other than good brakes)?
Perhaps I should investigate if one of Porsche's aftermarket brake makers will create a set of rotors in our bolt pattern and see what it would take to get the calipers bolt up...
Doug (Dreaming of no brake warping after the covered bridge tour)
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 04-13-2002, 02:23 PM
I_Alcyone_I
that would be sweet. Please keep an update if you get more info.
Old 04-13-2002, 07:58 PM
Jamsvx's Avatar
Jamsvx Jamsvx is offline
Send a message via ICQ to Jamsvx Send a message via Yahoo to Jamsvx
Just on the subject of brakes, Blake (1992 SVX owner) and I checked out a Eunos JC Cosmo 20B (triple rotor twin turbo - see http://www.3rotor.com and http://www.dmrh.com.au)
Aside from phenomenal accelaration and torque, its ability to brake from a truely ludicrous speed (I, nor Blake, was driving) was gobsmacking!
A nice set of 4 piston AP Racing brakes sets would not go astray!
Regards
James
1992 charcoal grey SVX:
27 August 2002 to 27 January 2004 - she will be missed
Was back in Sydney for a while but not hot enough so now in Dubai! Has it been that long since I owned SVX-33H!
