Drove SVX today
Howdy y'all! Drove an SVX today; a '92. Seemed pretty tight, but had a couple of questions:
1. I believe the transmission is the original, has about 80000 miles on it. I had read that a sure symptom of future trouble is if the RPMs flare, especially between gear 2-3. When driving I didn't notice any "clunking" between any of the gears; between 2-3 the RPS seemed to hang for a split-second and then drop down (like it's supposed to I guess?) Didn't hear or feel anything at all when shifting into Reverse or Drive; it was really smooth. 2. Seems to be some kind of "whining" noise coming from drivetrain or tires; not sure which. Not a roaring or grinding noise. Can hear when traveling fast, and maybe even more when slowing down to about 40 MPH or so (perhaps because of less wind noise). Not real loud, but could get annoying after a while. Is that a bearing or tires or something in the drivetrain? Is it something that needs to be fixed or normal? 3. When making a light turn traveling at medium speed at one point the drivetrain seemed to kind of shudder or something. Not sure what that is, only happened once. Thanks! |
the 2nd to 3rd flare isnt a sure sign of tranny failure. The plug behind the baterry will probobly fix that. and the noise could just be the tires on the road. try driving it over a newley paved piece of road to see if the noise goes away when you are driving over it. If it does its probobly your tires.
the plug behind the battery? what is this plug, eh? I'm just curious because i didn't know of it
There is a resistor behind the battery. It does something with the tranny to allow full line pressure when shifting. Supposed to decrease heat build-up, therefore increasing the life of the tranny. I took mine out for 2 days, then my dad yelled at me and told me to put it back in.
[/COLOR][/COLOR]-Scott My Locker 2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14 2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14 1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65 1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07 1994 Pearl White LSi Bought: 2001? Sold: 2004? |
ohh i see now, i'm illiterate i think...haha...
So, does anyone know what the whining noise could be? Sounded kinda like it was coming from the drivetrain.
Thanks! |
I know that noise!
I have a winding noise that comes from my car too. I brought it in to see what the problem was and it seems that the drive shaft was rubbing on a heat sheild. They think that it is no big deal and not to worry. It does have a different tone from speed to speed. It is there sometimes and others not at all. I hear it most comming from under the gearshift when the windows are closed. When the windows are down I hear it echo from everywhere. Of course, i never hear it when i am stopped? Hope i was of some help!
-G |
Is it something that would need to be looked into? (if what you are talking about). It's not a grinding noise, and it's not a roaring noise (like I hear described as wheelbearings), it kind of sounds like tire noise but not sure.
Tough thing to do a diagnostic from across the country. If you could, can you post a sound clip? Lwin
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
I would if I could, if I end up buying it I will. It doesn't sound like it's from the corners, It sounds like either underneath or towards the back. Also not sure about the shudder I heard (or felt?) as making a relatively light left turn at about 35 MPH.
Not good. A low speed shudder (esp. while accelerating) while turning is usually the transfer clutches. Seems like there are too many bad noises. Better get it evaluated by a trained tech or look elsewhere. Also check yer basics... sweet pink tranny oil and all history. B.
How long do they last at that point? Drove it for about 30 mins and it only happened once, couldn't get it to happen again.
Also, it seemed to happen at about 5 Hz (5 times per second) for maybe a second or so? Could be off, not sure how helpful that is anyway...
If the clutches are sticking it would increase as the case gets warmer and set an error code. Also you would get the same effect with dissimilar or mis-inflated tires. Did you check the tranny oil? B.
