Old 05-29-2006, 04:41 AM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
Matt,
My check engine light comes on intermittantly, its an error code 34 (ERG Valve) cusing my problem, no real poplem regarding drivability or damage, just needs the sensor replacing (according to Subaru Penrith)
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 05-29-2006, 05:05 AM
dynomatt dynomatt is offline
Just what is the procedure to check the codes on teh Aust spec versions?
Old 05-29-2006, 07:39 PM
JDW-SVX's Avatar
JDW-SVX JDW-SVX is offline
it's ruby red - not burgundy!!
You need to access the diagnostic connector (black plug) under the driver's side kick panel.
Do not touch the yellow plug - that one is for the Select Monitor.
Next to the black plug, you should find two blue wires, with exposed connectors.
You need to plug one of them into a particular pin on the black plug - I will find out which one when I check my service manuals!
Once you have done that, turn the ignition to "ON", but do not start the engine.
The "CHECK ENGINE" light will then flash all fault codes that have been set by the ECU.
Jason.
1992 Charcoal Grey SVX - 165,000km
1992 Ruby Red SVX - 165,000km
....now with sequential VIN numbers!
1986 Holden (Isuzu) Piazza Turbo - 225,000km
1993 Mercedes W140 S500 Coupe - 153,000km
1990 Mercedes W124 300D - 313,000km
EG33 + 4EAT + VTD AWD = SVX
Old 05-29-2006, 07:45 PM
Thanks Jason...keen to hear.
Old 05-30-2006, 02:13 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
What else car do you drive and make you think it's sooo slow? Maybe the one you tested need some works..
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 05-30-2006, 05:30 AM
JDW-SVX's Avatar
I have the details!
To access the "Read Memory" mode - which displays previously stored fault codes, you need to connect one of the blue wires to pin number 2 of the black connector - counting from the top left, with the connector tab facing up.
Jason.
Old 05-30-2006, 08:37 AM
sssvx, dynomatt stated he was suprised at how low the car was, not slow
Old 05-30-2006, 02:41 PM
Thanks...yeah low. Wasn't too slow actually. I was prepared for it to be slow given the power to weight, but I was actually surprised.
Old 05-30-2006, 10:20 PM
SSSVX's Avatar
Thanks...sorry, missed reading the 's'
Hope you get one you like in the coming days.
-SSSVX
