Old 03-27-2006, 10:22 PM
5/6 speed kits for sale
Well after some thought and finding there to be reasonable interest, I am producing the 5/6mt kits. These kits will be made to order so I will need time to actually make the parts once you have placed the order. Detailed instructions will be included with the purchase. By then end of the week I will have them drawn up and I will post them here. Below are pictures of parts that will be included in the kit. I am also willing to sell parts individually for those interested.
X-member $150 + $75 core
Pedals (brake/clutch/gas) $150 + $30 core for gas pedal
Shift linkage $100
Brake booster $20 + $50 core
Old 03-27-2006, 10:51 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Looks good Tom. Might be putting in an order in a couple months. Is the brake booster needed or jsut an option?
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 03-28-2006, 12:20 AM
intelisevil's Avatar
<<<Alcyone
Good Work!!!
Please include exactly what you are needing as far as 'core' parts. I'm pretty sure I can figure out most of the SVX parts. When I start scavenging other Subaru parts, I want to make sure I get the correct ones.
Thanks Again,
Dan
Old 03-28-2006, 10:52 AM
The booster is an option. It is not too hard to do but for those looking to keep is simple, I can provide the service for them.
Good Work!!!
Thanks Again,
Dan
Core parts are as follows
Xmember- Auto X-member and cross brace
Pedals- SVX gas and brake pedal boxes
Linkage- Standard(manual) shift linkage
Brake booster- SVX brake booster
A few advantages of this kit over the small-car kit are listed below
+ Costs less
+ No welding required
+ If a problem does arise, I will work with you to my best to get it settled peacefully
+ Known to hold up under very tough conditions(I and others who have had me convert their cars have beat them silly and my parts are known to hold up under the most abusive conditions, even a stage 3 supercharged car powershifting )
Downsides
- The kit's components may need some grinding for perfect alignment of bolt holes. For those of you familiar with welding will know what I mean when I say, metal shrinks after welding.
- Does not yet incude parts like the transmission, rear differential, driveshaft, clutch, master/slave cylinder, flywheel, flywheel bolts, starter, etc... A complete parts list will be available when I wrtie up some instructions.
Old 03-28-2006, 11:25 AM
AFBeefcake's Avatar
Subaru Swapper
Must start saving. I'll be conntacting you once I get money and parts.
How long would you say it takes to swap the auto out for a wrx 5 speed? With all the parts inhand and ready to go.
2005 Legacy GT
My WRX's Cardomain Page
Old 03-28-2006, 02:34 PM
He's probably got it down to a day by now
Old 03-28-2006, 02:50 PM
I would say 4 days at least for some who has done it before and knows the steps and shortcuts.
Old 03-29-2006, 11:48 AM
parts list
Parts list for 5/6mt swap
__ 5/6mt assembly
__ 5/6mt shift linkage(be sure to get all the pieces)
__ 5/6mt starter(both are the same at least for wrx5mt and sti6mt)
__ Helicoil kit for starter stud(late model transmissions)
__ 5/6mt slave cylinder(hydro only)
__ 5/6mt Master cylinder(hydro only)
__ Hydro clutch line (both hard line and soft line)
__ Neutral Safety Switch(for pedal box)
__ Brake/Clutch Pedal assembly
__ Clutch Kit(disk, pressure plate, throwout bearing, pilot bearing)
__ Flywheel (transmission specific)
__ Flywheel bolts(longer than flex plate bolts)
__ Pressure plate bolts
__ Transmission mount
__ Rear shift linkage mount(stock or homemade)
__ Matching rear differential(n/a for wrx transmissions)
*If using the 3.90 R180 be sure to obtain a set of rear axles as well
__ 2" extended driveshaft(for all 5mt transmissions)(95-99 Legacy 5mt shafts are known to work with minor modification)
*N/A if using 6mt
__ 5/6 quarts of gear oil
__ 4 quarts of brake fluid(bleeding brakes and clutch)
This should be about it. Please correct me if there is anything more
Old 03-29-2006, 05:53 PM
pavanbabut's Avatar
__ 5/6mt assembly
*N/A if using 6mt
Looks gr8. I am already thinking of going for 6mt as soon as I find a good deal on the used one. Anyway to be clear, by N/A(n/a) you mean stock (i.e. stock ones). right??
-Pavan
Old 03-29-2006, 06:56 PM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
Excellent!
Ok, this is awesome. This will save me a lot of trouble (probably).
I have a few questions though. Forgive me if I'm asking something retarded, but I have little experience with this sort of thing. How does this "core charge" thing work? I pay the price + core, then get the core charge back when I've sent you my old parts?
Also, what is the brake booster needed for? Does it improve clamping force of the calipers or something?
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 03-29-2006, 08:46 PM
-Pavan
N/A means not applicable
yes thats how the core works. the brake booster modification is needed to work with the new pedal box as it is closer to the firewall
Old 03-29-2006, 08:50 PM
How about a 'package deal' for ordering all the parts at once?
Also, how does the metal you're using underbody hold up to road salt?
Old 03-29-2006, 09:52 PM
gest24's Avatar
#1 6MT In Cali
Ok Tom, you said the brake booster was an option and not "needed" for the swap, but I just read in another part of the thread it is needed. Just some clarification would be awesome. Going, junk yard surfing next week for some parts.
The pakage deal is a great idea.
RIP
84 VW Scirocco
02 WRX
Old 03-29-2006, 10:27 PM
pavanbabut's Avatar
Can you seperate the parts list for 5/6mt into 2 sections so that one section will be having all the parts that doesnt need any modifications to be done (which are right bolt on into our svx, like tranny starter etc) and the other section with those that need modifications (like x-member, pedal system etc) and that we can order from you.
thanks,
-Pavan.
Old 03-30-2006, 03:21 AM
umm... it already is seperated...
Gest24, the booster out of an imprezza will work as long as it is for a hydro clutching 5mt. Or you can cut and die the SVX booster to the correct length to work with the new pedal assembly.
