Old 07-27-2005, 12:04 AM
Merz's Avatar
Merz Merz is offline
halfsharkalligatorhalfman
Question Carrier Bearing
I was under my car looking for rattles yesterday and noticed that my driveshaft is very loose. I can move it up and down by an inch or so by hand. Is this normal, or is my carrier bearing worn out? Im assuming it is worn out, because when i hit bumps while driving, the driveshaft rubs on the top of the exhaust heat shield and makes a terrible noise. I bent the heat shield down as just a temporary fix. If it is worn out, is there any hurry to fix it? It is $160 at subaruparts.com. Thanks alot. -Evan
`92 pearlie 220k
Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley
'00 GMC Sonoma ZR2.
Old 07-27-2005, 09:55 AM
alia176 alia176 is offline
Perhaps you're referring to the Pinion bearing? Even so, 1" of movement of the driveshaft is way unreasonable. Park the vehicle and fix it!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 07-27-2005, 01:42 PM
Merz's Avatar
its the bearing thats in the center of the driveshaft between the tranny and the rear diff. subaruparts.com calls it the "center bearing". I drive a lot, and very spiritedly, and have not noticed anything strange in the way it drives. but youre right, i should probably hurry and fix it before something worse happens.
`92 pearlie 220k
'00 GMC Sonoma ZR2.
Old 07-27-2005, 02:01 PM
I believe it's most commonly referred to here as the carrier bearing.
