Old 07-24-2005, 08:56 PM
Gravija Gravija is offline
Send a message via AIM to Gravija
Getting to the ECU/PS questions
I can't seem to get to the ECU, its really darn hard and i have a cable in the way blocking access to the brown box and white cylinder thing. Also, i popped most of the dash off, but i can't get the whole suede thing removed to be put somewhere else. Any tips?
Also, i found an additive for power steering fluid at pepboys (who didn't have a 15 OD, 11 ID O-ring, they only had 15OD, 10ID ) that says it helps stop O-ring leaks/problems, will this help or do i have to take apart the whole system and replace the O-ring to get the fix?
Anybody near the Bay Area want to help me too?
Old 07-25-2005, 01:14 PM
There shouldn't be anything in the way of the ECU. I was able to get the ECU/TCU out without taking the dash apart.
As for the power steering o-ring, the additive isn't going to help it. More than likely the o-ring is either squished flat or completely missing.
