Old 07-24-2005, 04:22 PM
Green1995SVX
How To: Front Sway Bar Bushings
I always noticed that my new svx handled terribly compared to my old Green one, and always wondered why. I also have been experiancing some unknown clunking and banging in the front suspension. Today i had the suspension apart to replace the front right spindle/hub asy and noticed that my sway bar bushings were totally shot. I decided to execute a replacment right away while i had everything apart. I thought I would do a service and throw a how-to of the process on here.
First, Locate the sway bar bushing on your front suspension. Note that the hub assy is missing from my car since i already had it off for other reasons.
Now, if you're in the northeast, like me, you'll want to give everything a healthy coating of PB Blaster or other penetrating lube.
Now remove one of the two bolts holding the bushing retainer bracket in place.
And the other...
Once the bolts are removed you'll need to pry the retainer bracket straight down with a screw driver or other small tool.
You're now ready to install your new Sway Bar Bushing. Here is a comparison of what a bad bushing looks like as compared to a good example.
Green1995SVX
Now it's time to install the new bushing. Place the new bushing around the sway bar.
Now slide the retainer bracket over the bushing.
Now, with the bracket fully in place, line up the mounting holes with the flange on the subframe.
Next, reinstall the mounting bolts. This is the part where i wished i had 3 hands. You'll need to push pretty hard with one hand to get everything properly lined up.
Your new bushing is now installed! Time to go tear up those twisties!!
Old 07-24-2005, 04:48 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Should've cleaned your oil leaks up while you were at it Mike . I highly suggest doing the end links while your there as well! Definately worth it!
Old 07-24-2005, 04:52 PM
KCROGUEDOG
nice work i am going to do this once i get unlazy. i got my poly bushings on the counter begging to be installed.
Old 07-24-2005, 07:13 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Mike,
Stock bushings? .... Then again, I know you've got a few lying around
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-24-2005, 07:28 PM
benebob's Avatar
Honestly Bill I found no difference between the stock ones that shot out from abuse and polys on the racer. I did however notice a HUGE dif when I replaced all the bushings on my XT6 with new stock rubber.
Old 07-24-2005, 08:26 PM
SVXRide's Avatar
Ben,
Given the size of the stock bars, there might not be a big difference between new stock bushings and poly. I guessing, given the "marshmellow" durometer of the stock bushings, that there would be a noticeable difference over time (i.e. poly staying in one piece, stock tearing into multiple pieces....). Might be interesting to see what your stock bushings look like at the end of the season (then again, your springs are now so stiff that the sway bars may not be doing anything at all anyway..... )
-Bill
Old 07-24-2005, 08:29 PM
Green1995SVX
Bill-
I know i know, OEM is BAAADDDD, but this is all i had "on hand" at the shop
Mike
Old 07-24-2005, 08:31 PM
SVXRide's Avatar
Mike,
-Bill
Old 07-25-2005, 12:27 AM
Good how to. I will get it into the How-To Locker when I have a chance.
Old 07-25-2005, 03:26 AM
KCROGUEDOG
im looking for a 18 mm grinding bit for my drill to drill out the 11/16 front bushings i got from summit to fit the 18mm sway. the closest grinding bit i found was 11/16 which is 17.5mm should i buy that and barely grind it out winging it. or dont drill out and have a very tight fit if they will fit. or is there such thing as a 18mm bit. chike drilled out his in his how to.
Old 07-25-2005, 01:59 PM
That should also be submitted to the SVXipedia.
