Old 07-08-2005, 09:42 PM
Jayahalasi
oil change question
Going to change my oil this weekend... I've Never done this before. I want to test out Mob1l's 15000 mile oil.
what viscosity of oil do i need to use
5w-30?
also what kind of oil filter should I get?
thanks sorry for being a "tard", I'm Just new to this stuff
Old 07-08-2005, 09:59 PM
Khalil's Avatar
Khalil Khalil is offline
blah blah, blah.
I allways use 10w-30.. When u goto the store, they should be able to tell you which filter you need, or there will be a book that can tell you.
-Khalil
*1992 SVX Red. Now 100k and climbing
Tranny rebuilt @ 84k. Repaint @ 87k.
Mods (in order of install)- K&N air filter, ECUtune stage 1v.4, Alternator mod, removed intake resonator, B&M Supercooler, Window Tint, JDM Emblem, Hid Kit 5000K.
Old 07-08-2005, 10:00 PM
Jayahalasi
I guess worse case scenario I can Take it off First and take it down there and match it up....
Still If anyone knows What kind lemme know
Old 07-08-2005, 10:46 PM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
Oil Filter
I use Fram filter's on mine,along with Valvoline oil....10w-30.
The Fram # is 3593...go here to decide which 3593 filter you would like to use...http://www.fram.com/
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
Old 07-08-2005, 11:00 PM
914helo 914helo is offline
Remember the SVX takes more oil than most cars so make sure your drip pan is large enough. You don't want your pan to be full and to still have oil coming out (been there done that on a different car!)
Kent
Old 07-09-2005, 12:24 AM
Oh yes, the good ol school of hard knocks!
Old 07-09-2005, 09:23 AM
alia176 alia176 is offline
Unless your engine has NO leaks, I wouldn't go over to synthetic just yet! As soon as you switch over to M1 synthetic, you're going to experience even more oil leaks. I'm a big fan of Puralotor or Mobile filters. I haven't use FRAM filters for any of my vehicles as of eight years or so. Just my opinion.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 07-09-2005, 10:33 AM
n00b on demand's Avatar
mobile high mileage oil is good ****!
Old 07-09-2005, 10:38 AM
I would agree with the Puralotor filters unless you are going to use a Subaru filter. I use both of these. Soneone gave a link to a review of filters and the Puralotor was rated far better than the Fram. I use a dino/synthetic mix - 10 - 30 oil and change at 3,000 miles. jmo
Old 07-09-2005, 12:02 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I think given that today's engines run soooo much cleaner than yesteryears' did, due to efi and electronic ignition, that oil choice isn't quite as important as it used to be, ditto for filters. If you are changing the oil and filter at 3,000 mile intervals and aren't using the cheapest stuff on the shelf you'll probably do just fine. I agree that synthetics and blends are great, but are they really necessary and/or cost efficient?
However, oil weight is more important as most OEMs have employed designs that make use of lighter oils to save fuel. These designs, such as low-tension piston rings depend on the correct oil in order to survive. Ask a Saturn owner if their engine leaks or burns oil. If they say "yes", I'll bet they don't adhere to a very ridgid maintenance schedule nor they use the wrong oil. Saturn isn't the only make to employ these designs but they are notorious for these problems. Also consider that engines designed for lighter oils have different hydraulic lifter/follower designs -misfiring and burnt valves can occur as the devices can't always bleed down as quickly as they should, holding the valves slightly above their seats when they should be fully closed.
Old 07-09-2005, 02:45 PM
Manarius's Avatar
Manarius Manarius is offline
Yeah, I think the SVX takes like 6 quarts (most drip pans are not that big). Funny, the SVX takes the same fram filter as my legacy does...similar engine design though.
I myself run 20-50w only because I have a leaky gasket somewhere and heavy oil means I lose less over time. It's killer on gas mileage, but I think my new Bosch 4+ spark plugs make up for that.
-Jason
-Obi Wan Kenobi
Old 07-09-2005, 03:55 PM
I went into the store the other day to get an oil filter for my Outback and found that it takes the same one as the SVX. Yes, I was a little surprised too.
Old 07-09-2005, 04:47 PM
rhhnx
Personally I like the K&N HP 1004 oil filter. the nut welded on the end makes it a lot easier to get the filter off.
Old 07-09-2005, 05:23 PM
Manarius's Avatar
Getting the oil filter off is rather easy. I can get it off with my hand. The problem is, the way the filter sits, as soon as you undo it, you get oil all over your hands.
-Jason
-Obi Wan Kenobi
Old 07-09-2005, 06:09 PM
thundering02's Avatar
Giong back to the beaters...
Try working at Valvoline I do that all day... most times after running for quite sometime And if any body buys a pontiac sunfire and asks me to change the filter for them be suprised if you don't get shot.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
