Old 07-05-2005, 11:52 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
driver side ebrake diagram? and your bolt removal ideas
Does anyone have a diagram on how and in what steps to reinstall the ebrake. I almost have the hub off, still working on the control arm bolt and abs sensor, but i am really worried about getting the ebrake put back together properly withot fumbling with it for days. Any help and suggestons would be helpfull. Eitherway im looking forward to a nice quite ride when this is all done! without a competent dealer or access to a press i jsut got some hubs from a parts car i knew had a really nice quite ride. It may have been the cheap way out with lots of work, but atleast i will know one to do it? anyways, thanks guys and i appreciate the help in advance.
also what were you tools of choice for removin the abs sensor? also, whats your guys diy best ways to removing 200k mile wisconsin control arm bolts?
thanks in advance!
phil
~Phil
Old 07-09-2005, 10:33 PM
Phast SVX's Avatar
well thanks for the help everyone, figured it out on myself and it really isnt that complicated with a simple picture. if anyone needs it in the future contact me
phil
~Phil
Old 07-10-2005, 09:48 AM
immortal_suby's Avatar
Thread Killah
Sorry man, I don't think anyone knew how to do it ! Never had to change an e-brake yet.
Locker Link
2015 BRZ Limited 6MT
Old 07-10-2005, 06:01 PM
Sorry Phil.
I just changed my computer and I can't get my Epsom scanner to work with it. Bugger
Old 07-10-2005, 08:26 PM
lee lee is offline
Phil,
Sorry I didn't see your post in time (glad you got it sorted) - but just to be clear for anyone reading this, you're talking about the bits inside the rear brake rotor/hub, correct?
If I guessed right, then any other readers should know the e-brake part of the hub is almost an exact match to old drum brakes on any Ford, Chevy, etc. Same sort of tools work well, i.e., spring pliers, etc.
Old 07-10-2005, 09:11 PM
I have never needed to change them either. It is good to hear that you got them changed ok. If anyone comes across a diagram, I can put it in the How-To Docs.
Old 07-11-2005, 12:26 AM
Phast SVX's Avatar
i will scan a diagram tomorrow that i found today (figures)
phil
~Phil
Old 07-11-2005, 05:11 PM
Also submit it to the SVXipedia on http://svx-iw.com
Old 07-11-2005, 09:09 PM
Phast SVX's Avatar
will do. I did not need to replace it but was neccisary to remove the hub. you must dissemble the entire ebrake assembly and swap it onto the new hub. I will need to be doing this in a few weeks for the othreside and will try to do a writeup for a complete spindle swap/removal.
phil
~Phil
