Old 07-05-2005, 05:32 PM
DoLittle
Just two new tires?
If you have two used tires that have some ware would it be OK to put on two new tires with the same size/tred on an AWD car like the SVX?
Old 07-05-2005, 06:04 PM
michael's Avatar
michael michael is offline
What Potholes ???
I would recommend putting 4 tires on the SVX two are not enough to keep all of the rotors off the ground.
Wanted: Steering Wheel
Old 07-05-2005, 06:08 PM
michael's Avatar
What Potholes ???
I had to
I wouldn't recomend just 2 unless the wear is comparable, I think it wears out the clutch packs.
Old 07-05-2005, 08:09 PM
n00b on demand's Avatar
your going to need 4 new tires.....if the 4 tires have different amounts of tread left your going to destroy the AWD system.
Old 07-05-2005, 11:56 PM
If the tread is very very close to being the same, I would put the used ones on the back. I would do that as my last choice though. New tires all around would be the best thing to do.
Old 07-06-2005, 12:34 AM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
Let me tell you from experience, buy all four at the same time. I bought one to hold me over for a day until I could get the money for the rest, and the ride was not fun. The whole car shudders if you do that. If memory serves me right, the part taking all the abuse is the limited slip differential. I can't recall as to whether our cars are LSD or not. If it is not LSD, then it is just the differential taking all the punishment. And that one day of driving probably contributed to the rear axles not getting power in my old car.
Check the tread wear, if all tires have really close to the same amount of tread, then by all means proceede.
Keith
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 07-06-2005, 12:37 AM
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
i just put 2 new tires on my brother's legacy gt cause the 2 left tires blew out. I put the new ones on the front and the old ones on the rear. the car drives fine because the old tires had <1k miles on them probably i'm not sure.
Also the tires on my svx the tread on the fronts and rears are noticibly different because i don't think the previous owners ever rotated the tires. This reminds me that i need to get wheels/tires soon.
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
Old 07-06-2005, 12:09 PM
That shows the importance of rotating them.
Old 07-06-2005, 02:04 PM
Keith
every svx has a LSD
Old 07-06-2005, 09:10 PM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
just 2 used tire's
Like everyone is saying,it is ideal to replace all 4 tire's at the same time.However if $ is an issue right now,putting 2 tire's on is ok as long as they go on the same axle,and are the same speed rating..H,V,Z,W...etc as the 2 tire's they are going to be matched up to.Same size and width also,that can play with your abs system if the diameter is smaller or larger,since all 4 wheel sensor's won't be reading the same approx wheel speed.
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
Old 07-06-2005, 09:49 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
You have a 1/4th of an inch diameter to play with accorinding to Subaru but even any difference will cause the tranny stuff to heat up just like driving a part time 4wd on the dry road. Make sure if you do it that your tread isn't too far gone on the tires you have and be sure to use the SAME TIRE with the SAME TREAD DESIGN on it!
