Old 08-01-2005, 07:04 AM
94svxred 94svxred is offline
I'm going to call the shop that has done a lot of work for me to see if they will put in the springs! I trust them , so I'll let you know what they said I'm getting excited . I think I can sneek this one passed my wife . Wish me luck (If see can't see it ,she won't complain)
Old 08-01-2005, 08:14 PM
overdalimit
READ CAREFULLY!.......Don't ever cut a coil spring! Under any circumstances. I won't even get into why not..Just DON'T do it! Buy the lowering springs instead.
Old 08-03-2005, 03:07 PM
I promise NO CUTTING HERE
Old 08-03-2005, 06:08 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Worked fine for our racer . Isn't a long term solution and is something I wouldn't do for a street car b/c of the liability these days but one coil off the front of an SVX is about a 1/2 inch or so stock.
Old 08-03-2005, 06:19 PM
Well Here's my thought . If I have take everything apart to cut my springs anyways . I might as well have them replaced with proper lowering springs . Don't you think
Old 08-03-2005, 09:28 PM
benebob's Avatar
Up to you. I definately think the amount of coils is beneficial but I also understand the coils have been cut since well the dawn of the coil so I wouldn't be afraid to cut it and use it to "see" if you want that height or another. As for driving like that forever there are issues with cut springs that lowering springs don't have like not as much suspension travel since they will max out.
Old 08-06-2005, 07:33 AM
My biggest issue is that I don't think a 3/4" drop is the look I'm after! The look I think I want is at LEAST 1" to 1&1/2" drop in front. What to do and how too all replies THANK YOU
Old 08-06-2005, 07:48 AM
benebob's Avatar
Are you going for a look or better handling etc? Dropping that far probably will screw up your geometery beyond the abilities of most alignment shops to fix it. If you really want the look a WRX spring would work just fine. Probably about a 1 3/4 inch drop.
Old 08-06-2005, 07:52 AM
Do you think an inch drop would really mess with the handling That's what I don't want
Old 08-06-2005, 10:01 AM
benebob's Avatar
It can, our front control arms are pointed the wrong direction on our racer at the moment. I'm guessing it is about a 2 inch drop up there. I wouldn't street the car this way but in some ways it helps our camber out a bit.
Old 08-06-2005, 06:51 PM
mbtoloczko's Avatar
sans SVX
A stiffer front spring, an increased roll couple caused by excessively lowering the car, and less travel will probably make the car push even more in the corners. That would likely be the result of dropping the front 1.75". It would look cool though.
Mychailo
Visit my locker
Old 08-06-2005, 10:59 PM
If anyone wants a set of front springs to play with if they are thinking of cutting them, I have a set for sale with the rubbers for $50
Old 08-07-2005, 03:50 AM
benebob's Avatar
With rubbers. Hee hee!!!
Old 08-07-2005, 05:45 AM
Seriously , Don't you think the best way is to buy new springs and try not to Mickey Mouse the stuff. I'd buy new springs but I don't Think 3/4" is enough to get the look I want . I also don't want the car to drive like a it'd sitting on bricks either
Old 08-07-2005, 06:25 PM
benebob's Avatar
Yes new struts is the way to go. You'll loose some ride as you'll need stiffer springs. Personally, I'd get konis while you're at it as we blow our rears more often than W. says terrorism with 198lbs springs in back. I just suggested the cutting to see if you like the look. It will cause alignment issues though which isn't necessarily a bad thing.
