Old 06-29-2005, 06:15 AM
94svxred 94svxred is offline
Question Lowering front only
I have 18" Alesio Turbo wheels, but the offset is a little wide. If I have people in the back the tires will rub just a bit . My real question is . How to or what is the best way to lower just the front too make my SVX look better (nothing i can do about the back ). Don't get me me wrong, I usually won't have people in the back !(to much extra weight )
Old 06-29-2005, 07:57 AM
mbtoloczko's Avatar
sans SVX
You can cut one coil (or so) off the front springs, but I've been told that the cut spring tends to squeak against the spring perch. Other than that, you could buy a pair of my front springs.
Mychailo
Visit my locker
Old 06-29-2005, 08:36 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
You might try adding camber bolts in the back and cranking in a little negative camber to get rid of the rubbing.
Mychailo's springs are the best long term solution!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-15-2005, 02:30 AM
Thanks for the replies .I might just take you up on the offer for the front springs ,.How much for just the fronts?
Old 07-17-2005, 11:00 AM
mbtoloczko's Avatar
sans SVX
$190 shipped. I have several pairs of the 0.75" drop springs in stock.
Mychailo
Visit my locker
Old 07-25-2005, 02:56 PM
$190 not bad let me give it a little thought Thanks for the reply
Old 07-27-2005, 05:51 AM
What's the going rate at a shop to put in front springs only .I'm to old and tired to do this crap .Any replies are greatly appreciated!! The biggest problem for working on my car is that I work from home have 2 small kids 1&1/2 and 3&1/2.So to do these projects I only have weekends really and thats the time I want to spend with my wife (oh did i mention catching up on sleep)who works out of the house . So I guess I should change my screen name to MISTERMOM94L What I really need to know is what some of you guys and Gals (to be politicly correct)have paid for your spring jobs So I know what I'm looking at money wise! Thanks
Old 07-27-2005, 07:20 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
It would probably be about $200 or so to get them in including an alignment.
How low can you go??? With these springs my guess is you're exhaust would be touching the ground. There's about 350lbs missing up front on ours
Old 07-27-2005, 10:31 AM
mbtoloczko's Avatar
sans SVX
Not sure what you're talking about for the springs. He was asking about my springs which will lower his car by about 3/4" and increase the spring rate by 35%.
Mychailo
Visit my locker
Old 07-27-2005, 11:58 AM
benebob's Avatar
Read the post above mine! He asked what the rate to put 'em in would be.
Old 07-27-2005, 02:04 PM
not the spring rate...the labor rates
Old 07-28-2005, 03:50 AM
Thanks ! Sorry I wasn't more clear , I was asking about the Labor rates Your were right Tom !!
Old 07-28-2005, 05:42 AM
benebob's Avatar
Crystal clear to me. That's what I said would be about $200ish
Old 07-28-2005, 08:31 AM
i would say thats about right
Old 07-29-2005, 03:22 AM
So It sounds like about $400 or so and I'm covered . As I said in one of my other posts , This is a project that my wife won't see! ie: carbon fiber hood!
