Old 06-17-2005, 11:00 PM
Khalil's Avatar
Khalil Khalil is offline
blah blah, blah.
ps pump
question is,
my PS pump is hissing a little bit (and much louder while reving), and i think is going out. I allready did the Oring replacement, and it didn't do much. Also the fluid that was in the tank when i did the Oring was really dirty. What im wondering is, is my ps pump dieing or should i just try to drain all the fluid and replace with new fluid (ps fluid or tranny fluid?). and how much should PS pumps cost? (used and/or new)
thanks
-Khalil
*1992 SVX Red. Now 100k and climbing
Tranny rebuilt @ 84k. Repaint @ 87k.
Mods (in order of install)- K&N air filter, ECUtune stage 1v.4, Alternator mod, removed intake resonator, B&M Supercooler, Window Tint, JDM Emblem, Hid Kit 5000K.
Old 06-17-2005, 11:56 PM
I would change the fluid and while you are at it, replace the O ring agian. The cost is so little, it would be well worth it. I found on mine that I had done something wrong to mine and it needed to be replaced agian. Once I did, it was working fine again. Try that before you invest in a new pump.
Old 06-17-2005, 11:57 PM
Oh, and use transmission fluid, not power steering fluid.
