Old 06-14-2005, 05:25 PM
PaulSVX's Avatar
PaulSVX PaulSVX is offline
Exclamation FWD Mode
My car doesn't go in to FWD diagnostics mode, after placing a fuse in to the proper slot. Any ideas ?
Thanx
Old 06-14-2005, 06:12 PM
Do you mean the dash light doesn't come on or is there still power going to the rear wheels?
Old 06-14-2005, 06:50 PM
Mr. Pockets's Avatar
Moderator
My wife's Legacy had transfer clutch problems, so I put the FWD fuse in. That was fine, while I was waiting for the parts to fix it, but eventually the fuse stopped working. The light didn't come on and duty solenoid C was definitely trying to do its job.
The parts arrived, I fixed the problem and I didn't need to use the fuse any more. I never did find out why it wasn't working any more.
Why are you trying to use yours?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-14-2005, 07:25 PM
PaulSVX's Avatar
There is still power going to the rear wheels, I have a binding problem.
Old 06-14-2005, 07:28 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Don't drive it! Since I'm a betting man I have $1000 on it being your duty sol c so long as you're getting codes. Driving it+binding=heat=dead tranny. Get it to a shop asap or replace it yourself. You can do the dynositc on it at home to be sure but this is exactly what mine did when it went out. Was like $650 or so to fix at the dealer too so it isn't cheap.
Old 06-14-2005, 07:37 PM
PaulSVX's Avatar
Unhappy
I got my first import car 3 weeks ago - 1992 Subaru SVX, with broken almost in half, front diff. I replaced the diff case and all the gears as a set, It is all working however i'm getting a binding problem, and the front diff is noisy, so I have to diagnose a problem.
Is it a front diff noisy or binding causes it to be noisy (whines), or binding casued the front diff distraction in the first place.
Thanx for the input
Old 06-14-2005, 07:39 PM
PaulSVX's Avatar
duty sol c, is that the one in the transfer case (back of the trannsmission)
Old 06-14-2005, 08:53 PM
Bobb Bobb is offline
Awd
Hi Paul, You should double check that the gear ratio you put in the front diff is the same ratio as what was in it. Quite a few Subie diffs will fit in the case on a SVX, but it will not be the right ratio. I don't think it will show up as a code either. Take care, BOBB
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Yes, that is were it is. Did you replace the pinion with the front case, or leave the old one in? Ther may be a binding problem with the fron diff.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 06-14-2005, 08:55 PM
SVX-FF's Avatar
If you can get the last 8 or the car's vin call the dealer, they can use the vin to look up the final drive ratio. The local subie dealer did that for me about 7 times looking for the right tranny.
Steve
Are you in?
My Old Locker
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 06-15-2005, 06:11 AM
red95svx
Thanx for the input
Putting the car in FWD mode would eliminate a rear diff bind, but not a front.
Old 06-15-2005, 06:51 AM
benebob's Avatar
Not if it has a sol. c issue! Do you have a flashing power light at start up? If so your TCU is sending you codes. Do a search (I think of Earthworm's SVX Info library) of the self diagnostic for the tranny light. That should narrow things down for ya a bit.
Old 06-15-2005, 07:24 AM
red95svx
Maybe I wasn't clear. What I meant was that putting the car in FWD won't eliminate any front diff problems, but may eliminate rear diff problems.
Old 06-15-2005, 11:04 AM
PaulSVX's Avatar
The fron diff was replaced as a set, from another SVX, so gear ratio should be the same. The power light flashes 16 times when the car is started.
Old 06-15-2005, 11:13 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
This is definitely the TCU throwing a code. Go here for more info on how to check it out: http://svx-iw.com/
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
