Old 08-19-2004, 07:49 PM
TorG0d
font main seal
How hard is it to change out the front main oil seal on our motors?
Old 08-19-2004, 08:04 PM
immortal_suby's Avatar
Thread Killah
Easy
Remove radiator
Break crank pulley bolt loose (use long breaker bar and starter)
Slide off crank pulley
Take off front belts
Take off power steering idler pulley bracket
Take off A/C idler pulley bracket
Remove plastic timing belt covers
Rotate engine until all timing marks line up and use chalk or marker to mark belt and pulleys just to make sure.
Remove timing belt tensioner
Put vise grips or clamp lightly on timing belt on both cam pulleys to keep belt from slipping off pulley and jumping a tooth
Remove idler pulley for tensioner
Remove toothed crank pulley (slides right off usually)
Drill small hole in crank seal
Use mechanics pick to pull crank seal out (stick it through hole you drilled)
Put grease on new seal and tap it in evenly
Use vise to compress timing belt tensioner and put small allen wrench in hole in tensioner to keep it compressed
Put toothed crank pulley back on
Put tensioner on
Put idler pulley on
Make sure timing belt is lined up correctly
Remove allen bolt from tensioner
Put plastic covers on
Put the rest of the stuff back on
Fill radiator
Drive!
Just did it again this past weekend so it is still fresh in my mind
Ryan McDonald did a good timing belt how-to with pictures that covers 99% of the crank seal process.
Locker Link
2015 BRZ Limited 6MT
Old 08-19-2004, 08:52 PM
wawazat??'s Avatar
Yeah, I'm still around
Whic car Matt
yours, Kim's or the engine on the stand?
Todd
Down to none
Old 08-19-2004, 08:54 PM
Thread Killah
Kim's svx
Still haven't ordered all the parts for the one on the engine stand
Waiting for red95svx to be back in the parts business.
Locker Link
Old 08-19-2004, 08:56 PM
wawazat??'s Avatar
Get in touch with Langston Subaru in PA
tell them you were at the Reading meet and they'll hook you up with a hefty discount.
I'll get you their contact info tomorrow.
Todd
Down to none
Old 08-19-2004, 09:24 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally posted by immortal_suby
Easy
Remove radiator
Put tensioner on
Put idler pulley on
Fill radiator
Drive!
How long did it take you to do all of this Matt? Sounds like a pretty involved process...
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-19-2004, 11:16 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
I like how it says "Easy" before the long list of steps.
Old 08-20-2004, 02:12 PM
TorG0d
I was quoted about $150 to have a shop do it. Think I'll go that route, as our 1939 Ford tractor is in our garage due to transmission problems and I don't feel like doing this under open sky and on gravel. Thanks for the info though
Old 08-20-2004, 02:14 PM
Chiketkd's Avatar
$150?! That's a really good price... Has this shop ever worked on SVXs before?
-Chike
Old 08-20-2004, 04:30 PM
thundering02's Avatar
Giong back to the beaters...
Watch them do it but otherwise it sound like an awsome deal.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 08-20-2004, 05:24 PM
Thread Killah
Took me I think a little over 2 hours my first time - about 1.5 hours the second time including 2 labatts blues.
I'd rate it about $25 on my how much I'd pay someone else to do it scale.
Locker Link
Old 01-03-2005, 08:00 PM
Chiketkd's Avatar
I'm about to replace my front oil seal at svxfiles' place. Just got in my front oil seal and wanted to post pics in this thread as Matt left some good instructions.
-Chike
Old 01-03-2005, 10:13 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
You may find once you're in there that the crank seal isn't the problem but rather the oil pump o-ring is. Be careful to inspect while it's all apart.
Old 01-04-2005, 10:46 AM
svxpert svxpert is offline
<<Easy
Remove radiator
Put tensioner on
Put idler pulley on
Fill radiator
Drive!
Just did it again this past weekend so it is still fresh in my mind>>
Save yourself some time and just remove the fans, no need to remove the radiator. That way, you won't have half the problems the other guys are having properly bleeding the air from the system.
Old 01-04-2005, 06:27 PM
Chiketkd's Avatar
Thanks Beav. I may just pick up an oil pump o-ring from the dealer to have handy. While I'm in there might as well replace it...
-Chike
