Old 08-15-2004, 06:28 AM
thundering02's Avatar
Giong back to the beaters...
Manual trans Conversion on FWD
I've seen the conversions all over this site for the AWD cars but not for the FWD. Any suggestions where to get the trans for the swap from....?
Old 08-16-2004, 05:13 PM
Re: Manual trans Conversion on FWD
Hi, don't know why no one has answered this one.
I would think that any manual trans, out of any front wheel drive Subie would fit. You just have to pick which final drive ratio you want to use.
Some body else can tell you which trans has which ratios. But it would work.
Old 08-16-2004, 06:37 PM
FWD trans ratios please...? and recomendations for them please. And truthfuly I didn't know any Sube's had front wheel drive until I had done some searches on the internet.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 08-16-2004, 07:07 PM
I found some details but not exactly what I'm looking for...Legacy and Loyale also if the trans on these can handle the powerand weight of the svx? (*edit*) I just found NASOIC site reading through it....
Old 08-16-2004, 07:23 PM
svxhunter svxhunter is offline
5 speeds rock! :D
I'm also working on a 5-speed FWD project- well sort of. Mine will end up sitting amidship in a Corvair driving the rear wheels!
Anyway, you will encounter the same issues as the AWD cars. The same trannies (in FWD configurations), drive ratios, and issues (like if the tranny is strong enough to pull around the SVX).
Technically, the 4EAT was Subaru's strongest tranny in the '90's. That's why it's all they offered on the SVX. The manuals are all a little weak to be pulling around an SVX. The good news is that once the conversion is complete, replacement and repair become MUCH easier.
So, you will be looking for a FWD tranny from a Legacy, Impreza, Forester, etc. It was not designed to pull the weight of the SVX, but your future maintenance will be easier.
You'll need someone smarter than me to talk about specific gear ratios and model years.
Good Luck!
'92 LS-not-so-L: the "SVreX"- Saved from a crusher, an SVX racer built by home schooled students for less than $2000 (including purchase price). 13.8 second 1/4 mile. Autocrossing monster!!
'92 LS-L Claret: '01 RS 4:11 5-speed, Exedy organic, lightened flywheel, and Koni/ GC
Old 08-17-2004, 06:55 AM
You have to get a FWD tranny out of a Early Impreza or early Legacy to make it work...the Loyal has a different bellhousing....
Old 08-17-2004, 05:25 PM
Same years as the AWDs and I assume the same ratios?
Old 08-17-2004, 07:50 PM
The FWD for the Legacy and Impreza was available from 90-95...I'm guessing they're all 4.11's...but don't know for sure
Old 09-30-2004, 02:51 PM
deruvian
Do you want to keep it FWD? Because you could easily convert it to AWD, which would allow a much larger selection of transmissions...
Old 09-30-2004, 03:06 PM
troth
oohh
ok I'll bite does anybody have a write up on a fwd to awd conversion?
thanks
tr
Old 09-30-2004, 08:47 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
I don't think anyone has ever done a FWD-to-AWD 5-speed swap before. It wouldn't be hard, you would just need some of the AWD parts from another SVX along with your donor car.
BTW, you have a PM .
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 09-30-2004, 09:52 PM
svxsubaru1's Avatar
I aculy think they have around a 3.7 or 3.9 final drive ratio, becasue of less weight from the rest of the AWD and the less drive train power loss.
I know that in the Autos the fwd compared to the AWD trannie on the same car had a higher final drive ratio.
I would either pull one from a legacy or impreza there the same trannie throught the years, and modles pretty much.
The FWD 5spd conversion would only be easier, just follow the AWD instructions minus the drive shaft extendind, rear end ratio swap. I am almost 100% certain there almost identical.
Old 10-01-2004, 05:45 AM
It would be exactly like my write up without the rear diff and driveshaft stuff....the trannys and cables are the same (minus the driveshaft yoke)
