Old 08-10-2004, 01:10 PM
tancred
EGR Part #
Anyone have the EGR Part Number, I Tried looking this crap up and all I got was a SUBARU PURGE VALVE ASSEMBLY...
Ah...yeah..so I guess I need the part number so i dont buy the wrong thing..
Thanks
Old 08-10-2004, 01:44 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Do you need the EGR Valve, or the EGR Solenoid?
You'd be looking at part number 1 or number 7.
http://www.subaruparts.com/diag/?mod...category=081-A
Randy Johnson
Mike Davis -- at Reading VI
Old 08-10-2004, 01:50 PM
tancred
No clue, im getting a check engine for EGR and gas mileage went straight down. So.......Both probbably...heh..
Old 08-10-2004, 01:51 PM
tancred
I took it out, cleaned all removable parts with parts cleaner stuff, and put it back in, reset codes, and it flagged it again. So....
I dunno, i think i heard kicking it works too...
Old 08-10-2004, 02:01 PM
Aredubjay's Avatar
Notice, so as not to seem like a post wh*re, I edited my previous post to include the part numbers.
This could have been my 10,901th post.
Randy Johnson
Old 08-10-2004, 02:03 PM
tancred
LOL...Post wh0re..
Old 08-12-2004, 09:41 PM
michael's Avatar
michael michael is offline
What Potholes ???
could you find it in your heart to do a how to and let us know what parts you used and include lots of pics? This will be the last of my error code problems so far I had 6 I needed to fix
Wanted: Steering Wheel
Old 08-12-2004, 09:53 PM
tancred
Yeah, I will make a how to.
Old 08-13-2004, 12:27 PM
michael's Avatar
What Potholes ???
Thank You!
Old 08-13-2004, 12:41 PM
nordique14's Avatar
Who watches the watchmen?
Check to make sure you are only getting an EGR fault code. My coolant sensor went south and it tripped an EGR code and a coolant sensor code. Once I changed the sensor it fixed the EGR system.
Old 08-13-2004, 07:06 PM
michael's Avatar
What Potholes ???
It is proably a stored code for the egr I bet it will come back, sorry
Old 12-28-2004, 12:53 PM
RobSVX
Where is EGR ?
I pop the hood, remove the cover over the throttle, but still can't find it ? I know what it is and what it does, but its elusive...?
Old 12-28-2004, 07:02 PM
svx_commuter's Avatar
When you stand at the front of the SVX and look at the engine it's at the rear of the engine on the left side. You can't see it because it is hidden under the wires and hoses. It may be easier to spot the stainlees steel heat shields on the tubing that connects the manifolds to the valve. The heat shields are held on the tubing by squeeze tangs. This allows the heat shields to be pulled off the tubing. Happy hunting
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 12-28-2004, 09:05 PM
michael's Avatar
What Potholes ???
Thanks commuter, I've been looking for a pic for him but none could be found. I myself would like a detail of what is what as far as what is the EGR Solenoid and what is the EGR Valve. I was hoping someone would have done a how to on cleaning or replacing the EGR. I currently have a code for it. I'm not to good with directions either
Old 12-28-2004, 09:24 PM
RobSVX
Thanks Guys (again)
I've got 3 codes (all at once ?): RH O2 Sensor, VSS2, and EGR.
I'm getting the O2 and VSS2 from folks here on the forums (used) since I didn't want to buy new parts for an old car...heh.
I'm quite handy with cars, so replacing them shouldn't be too bad (sometimes the O2's take a torch to heatup the exhaust flange, so luckily I've got a Mapp Torch).
Also, noticed that the ECU 'may' give an EGR code if its pulling other codes too. I'm going to get the O2 and VSS2 done, then clear the codes and maybe the EGR will go away.
They're hard to find used, so not many folks part out the engine (and its where it lies). Also, there's a few valves and hoses that makeup the assembly...
Anyway, you know what I'm doing this weekend !
-Rob
