Old 08-03-2004, 09:33 PM
PatrickB's Avatar
PatrickB PatrickB is offline
Send a message via AIM to PatrickB
suspension setups
I figured down the road I will be investing in koni and gc setup. Does anyone make poly urathene suspensoin kits? i think i have some crappy sway bar end links cause it pops going around turns. only thing i think would 'pop' going aorund a turn.
Old 08-03-2004, 10:10 PM
mbtoloczko's Avatar
sans SVX
The endlink bearings are actually top rate. Ball joints are used on both ends in the front, and a balljoint/bushing combo are used in the rear. If anything is wrong with the swaybars, the front mounting bushings are gone.
No polyurethane full suspension kits (and there never will be), but a few people have used polyurethane swaybar mounting bushings. See my locker for an example. Improves turn-in response and maybe reduces lean a tiny bit.
Mychailo
Visit my locker
