Old 07-28-2004, 11:15 PM
Interior Dome Light
I've had my dome light out for a while now and thought I would see if anyone might know an area to check to get it working again. It works when the passenger door is opened but not for the drivers door. A while back my power locks were freezing up and i sprayed wd-40 on them and might have even taken them apart. I think the problem started around that time. Even the trunk activates it. Any ideas. I would think some of you have had this happen. Any ideas.
-Mike
95 Pearl Blue L
Old 07-29-2004, 05:43 AM
red95svx
Sounds like the drivers door light switch is broken. I believe the switch is built into the outer handle assembly. You may have shorted something when you drenched it in WD 40.
Old 07-29-2004, 07:53 PM
DOME LIGHT
Dave, thanks for the information on the dome light question. I took the door panel off and checked where the door handle is on the inside. There is a white plastic piece with two wires going in and a bundle of wires going out. They're like fused into the plastic. It has a number (2174) on it. This is the only electrical items at the handle area. This may be the problem. Nothing else seemed out of place or disconnected. Should i replace this item. Also, the panel that shows whether you're in P,R,N,D etc... lights up only occasionally when night driving. Any ideas would be great. Tracing the electrical problems seems to be a nightmare. At least for me.
Mike
95 Pearl Blue L
Old 07-30-2004, 07:23 AM
red95svx
If you really want your courtesy lights to work, then I would replace that switch. Unfortunately Subaru does not show any available at this time, and even if they did the list price is about $100. So, I would check around for a used one if I were you.
As far as the shifter light, I've had a couple that had burnt bulbs but I'm not familiar with it sometimes working and sometimes not. Sounds like a loose wire.
