Old 07-26-2004, 01:34 PM
Whoru465's Avatar
Whoru465 Whoru465 is offline
The name's...
Send a message via AIM to Whoru465
Question Iris
If the IRIS valve wasn't working (i.e., stuck in full open/closed or somewhere in between) How would you tell? Would it set off an error code? Or would the horrible performance be enough to tell? Thanks.
-Mike
'92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91
"It says here, 'Breakfast any time'...
That's right...
In that case, I'll have the pancakes in the Age of Enlightenment..."
Old 07-26-2004, 04:40 PM
Re: Iris
If there was a problem in the electrics that work the valve, then it would post a code. If it was the butterfly valve stuck or mechanical not working, then no code. A solenoid valve turns on stored vacuum to pull the valve open, a spring closes it
If the IRIS valve was stuck closed, there would be good acceleration up to 4000 rpm, then the engine would run flat from there with little torque. If it was stuck open, it would be gutless below 4000 rpm, but run hard above 4000 rpm.
It is not known to give trouble, but there is allways a first. What problems are you having?
Old 07-26-2004, 04:51 PM
Mr. Pockets's Avatar
Moderator
Re: Re: Iris
Originally posted by oab_au
If the IRIS valve was stuck closed...the engine would run flat from there with little torque.
Do you really think that the IRIS has that profound an effect on the engine's performance? I mean, I'm not saying that it doesn't do anything. I'm just curious, now, how 'gutless' it would be without the IRIS working properly.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-26-2004, 05:45 PM
immortal_suby's Avatar
Thread Killah
I suppose you could unplug the vacuum line to it and find out.
Locker Link
2015 BRZ Limited 6MT
Old 07-26-2004, 06:04 PM
Re: Re: Re: Iris
Hi Nick, yes mate, it is responsible for the two torque peaks that we have seen in the dyno graphs. If it was stuck open, the low speed Inertia pressure would be lost thorough the valve to the other side. Instead of building pressure in the cylinders on each side.
Stuck closed at higher rpm, the resonate inlet pipes could not induct a full cylinder of air, from one side, it needs both sides to be joined, to provide enough chamber volume to supply the air in the time available.
Old 07-26-2004, 08:32 PM
Whoru465's Avatar
The name's...
Thanks for the replies. I'm not having a problem, but I think I was trying to ask what Pockets asked. Kinda, whats the potential for a bunch of us driving around with non-functioning butterfly valves and never even knowing it?
-Mike
That's right...
