Old 07-20-2004, 10:53 AM
Whoru465's Avatar
Whoru465 Whoru465 is offline
The name's...
Send a message via AIM to Whoru465
Hissing...
So I'm under my hood doing my daily poking around and I notice a hissing sound coming from somewhere in the area behind the steering pump. As the car warmed up the sound died a bit. Is it possible the intake is loose? I don't think its the pump because I haven't had any problems so far with the steering (knock on wood) Any thoughts? Thanks.
-Mike
Old 07-20-2004, 10:55 AM
n00b on demand's Avatar
I has a noise come when i started the car but it was more of a loud humming noise or something. It also stopped once the car warmed up. Adding Power Steering fluid did the trick.
Old 07-20-2004, 11:06 AM
Whoru465's Avatar
The name's...
I doubt...
It's the fluid as I has been staying level...This is definately an air sucking noise of some type. However, I will never admit my SVX sucks...
-Mike
'92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91
"It says here, 'Breakfast any time'...
That's right...
In that case, I'll have the pancakes in the Age of Enlightenment..."
Old 07-20-2004, 01:27 PM
poweredx2 poweredx2 is offline
It may be your battery I average one per year.
Old 07-20-2004, 01:31 PM
Mr. Pockets's Avatar
Moderator
Mike, how's your power steering working? The o-ring in between the reservoir and the pump has a tendency to get crushed and start sucking air in, bogging down the pump. Eventually the pump starts slipping against the belt, making the belt squeal like it's loose.
The o-ring is very simple and cheap ($2?) to replace, so I think I'd start with that.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-20-2004, 03:06 PM
Yeah i have experienced this air sucking noise too. I hear it from the inside...not too loud but i can hear it...doesnt happen alot only sometimes. And it also goes away when the car warms up.....only lasts for a few seconds. I should open the hood when it happens to see where its coming from.
Old 07-20-2004, 10:55 PM
Loose Manifold?
The inlet manifold is known to loosen and suck air. It is one piece, spanning a crankcase and two heads, with gaskets in between. So it needs to be checked once a year.
