Old 07-15-2004, 01:25 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
there was someone got out of his svx via the trunk when his both doors had problem.
maybe you can get into your trunk thru your backseat to check if your trunk release lever is at up or down position by using a torch light?
if it's at up position, maybe your problem can be solved....
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 07-15-2004, 06:43 AM
dcarrb dcarrb is offline
Originally posted by Chiketkd
Question dcarrb - does your key(s) not have a 'y' or an 'x' marked on them???
-Chike
Chike,
My valet key does have a "Y."
dcb
Old 07-15-2004, 07:19 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
That's awesome...thought I had a weird set of keys!
-Chike
Originally posted by dcarrb
Chike,
dcb
2006 Steel Gray WRX TR (sold)
Old 07-15-2004, 09:31 AM
It seems the lock switch behind the back seat can be moved rather easily and inconspicuously. This was a major problem for me because in order to unlock it I have to remove my sub box (not easy) then remove the stereo amp rack that blocks the access hole to the trunk.
I solved this problem by cutting a piece of foam to wedge into the hole for the lock switch. Hasn't been a problem since.
Old 07-15-2004, 12:27 PM
red95svx
Originally posted by SVX-FF
I went to the Subie dealer to get two new keys cut that had the black on the key. They had to cut them by code, 3 times. the darn keys still did not work.
Steve
I've seen this before. I bet they used the wrong key blank. Subaru uses two different types of key codes: one is four digits, the other is five. Each one has its own unique blank.
Old 07-15-2004, 01:07 PM
NeedForSpeed NeedForSpeed is offline
So, there are two nearly identical black grip key blanks??
And speaking of key blanks, can SVX keys be cut on STI blanks?
Are all STI blanks blue?
Thanks for the information Dave. But in my case, one of the five first-group keys did [barely] turn and start the car, while four failed. All the keys from the second dealer worked perfectly.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 07-15-2004, 01:28 PM
red95svx
No, the blanks are quite different...but that doesn't stop people from using the wrong one
No, the SVX uses a four digit code, the STI uses a five digit code......so they use different blanks.
No, only the "fancy" STI blanks are blue. You can get a plain metal blank if you want.
