gearbox!!!!!!
well here we go then!!bought me a 92 maroon and black beuty fsh etc etc from a dealer which bought it from a man of shall we say senior years? now being a little younger ith a slightly more aggressive driving manner(but not that aggresive!!!!!)my gearbox will only now get 1st and 2nd!!!! im transporting it down to hastings where i now live this weekend and my girlfriend is going to bail me out for the neccesary for the work just wondererd if anyones had a similar problem? and how they rectified it without having there pants pulled down over the price!!!!any advice would be more than welcome! and thanx for meet info !ill be there if i have to walk!!!!! cheers bilkox
Tough news.
Hi Bilko.
Sorry to hear you have box problems. What mileage is on the car, and was the tranny ever rebuilt? Do you know? Assuming I read your diagnosis correctly, your box is not shifting from 2 to 3. Correct? Assuming this is the fault, then 4 range will not be obtainable, as 3 is not selected. If the brake band was slipping, you would not have 2 or 4. However, it would rev up for no reason on going through 2 to get to 3, so this is probably not your problem or you would have mentioned the revving. Now, assuming no shift from 2 to 3 is your problem, the troubleshooter suggests three items as follows, two addressable on the car, the third, the box has to be taken out and stripped. First two first, they are a faulty control unit [TCU] the tranny computer in other words, or a valve sticking. The third one is high clutch slippage. If you have been a bad boy, too aggressive, , then you may have burnt this clutch, and the box needs a rebuild. Here is my advice for what it is worth. If you need to rebuild the box, you will have to replace the valves with a new set anyway. So do it now, it is relatively cheap, if it fixes the problem you are good to go. The valve chest is taken out from the tranny sump, no need to remove the box.[you will lose the oil, of course.] Go to an automatic transmission specialist, they will know how to do it. There are six valves in the cassette, replace them all. If the new valves give you four gears, problem solved. If it does not work, Tony Shale will have a TCU in the car he is parting out. You could possibly contact him to buy it, or he might let you try it. If that fixes the problem, you will be getting off cheap, and have new valves, which are a wear item anyway. If both of these fixes do not work, then you have no option but to have the box taken out, stripped and rebuilt, as it can then only be the worn high clutch if our diagnosis is correct. The rebuilder will fit new clutch material to all the clutches in the tranny. They tend to wear together, nobody ever replaces just one. Best of luck with it, I hope it is just the valves. Joe
Black Betty [Bam a Lam!] '93 UK spec, still languishing Betty Jersey Girl Silver '92 UK [Channel Isles] 40K Jersey Girl @ Mersea Candy Purple Honda Blackbird Plum Dangerous White X2 RVR Mitsubishi 1800GDI. Vantastic 40,000 miles Jersey Girl Last edited by svxistentialist; 02-25-2004 at 06:25 PM. |
gearbox part deux!!!
joe! thanx v v much for your reply!!!! sorry i didnt give all the info!you mentioneud revving !! and boy does it do that!! its an auto it picks up 1st goes to 8000 rpm and then picks up 2nd and just stays there!the mechanic (who said the mechanic was a bastard and who said the bastard was a mechanic!!!!!)said it was a kick down problem and did mention the valves sticking any way thank you so much for the info gonna try aand print it of now!! illget you a pint at the meet!!maybe two !!!cheers mate bilkox
gearbox part deux part deux
ps........its done a 109k and never had a rebuild!! bx
The old 1-2 or 1-3?
Sounds like you need a rebuild.
What you have just described sounds much more like driving in 1, slipping through 2, which is burnt out, then going into 3. So you would be driving in 1 and then 3. It can't go on to 4, as the brake band is worn. If the car is doing about 60 at 3000rpm, then you are in third, not second. If what I have described above is correct, be careful driving it. With the revving and slippage, 2 will get worse. Then the car will not be able to attain the conditions for moving up to 3, and you will have to drive it home in first. Get it fixed pronto, best advice. Phil is near you, see if he recommends a tranny specialist nearby. There is a thread where garages are recommended if you search. Joe
Pint
And I'll hold you to the promise of a pint!!
hello mate!! got the beasty back to hastings!!! had it transported! was lovely to be in her again!! just been talking to a fella (in the pub!! where else do you find so many experts?) and he seems to think that a channels blocked in the sump i told him that i have 1st and 2nd and reverse thats 2 channels out of the 3 spoken for so drop the sump clean all the channels flush through new oil new gasket and hey presto!!! sound feasible? anyway going to see a gearbox man this week ill keep ya posted! have a good weekend!! bx
The above descriptions sound exactly what happened to me!
I'm still waiting to get mine back (it took 3 weeks to get parts!), but won't be able to tell you the problem, as I had a different box rebuilt. Good luck! If you need a rebuilder, I now have a list of 3 or 4 that the guys and my own research found. Let me know if you need them. |
Thread Tools | |
Display Modes | Rate This Thread |
