Old 02-01-2004, 05:21 PM
The Monzta's Avatar
The Monzta The Monzta is offline
Talking On the Scrounge
Does anyone have a spare clip that holds the 'H-6' engine cover on? I lost one a few months ago and I've given up ever actually getting the right part from my Subaru dealer. They keep giving me one that's too small and the cover can be pinged off with the slightest leverage.
The Monzta
'96 Subaru SVX (111K) - UK spec
'85 Opel Monza GSE (71K)
'86 Opel Monza GSE (95K)
'93 Toyota Estima Lucida (37K) - JDM import
My psychiatrist says I'm suffering from paranoia........but he's always hated me!!!
Old 02-02-2004, 01:52 AM
TonyShaleUK
Got the same problem - and so has my spares car!
Old 02-02-2004, 02:54 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Ours are loose too. I was thinking of replacing them with roofing bolts.
http://www.discount-power-tools.co.u...t-with-nut.asp
I think it may be possible to epoxy the nut onto the underside of the metal bracket that the clips push in to.
Maybe worth a try?
Old 02-02-2004, 12:25 PM
Sonar's Avatar
Sonar Sonar is offline
Can't you just take a similar from an old subie interior?
As I remember there are several of those there.
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 02-02-2004, 12:54 PM
Unhappy
Mine came back from the last tranny revamp with one of the two missing.
Thought it would be easy enough to get another. Must make a trip to my local scrapyards and bring one with me for comparison.
Old 02-02-2004, 05:45 PM
The Monzta's Avatar
Guess I'll have to do the same. Why is nothing ever straightforward with Subarus?
The Monzta
Old 02-03-2004, 03:28 AM
Nobody Nobody is offline
Send a message via ICQ to Nobody Send a message via MSN to Nobody
Hi Mozta, BTW, how is your front lamp washer? Have you solved it?
Peter
Old 02-03-2004, 06:11 AM
Green1995SVX
The reason they wont stay in is because the rubber grommit in which they fit tends to wear and shrink over time. This causes it to lose its affectivness in holding in the clip. Replace the rubber and the clip and you'll be good to go!
Mike
Old 02-03-2004, 11:09 AM
The Monzta's Avatar
Peter
Hi Peter,
For some reason my windscreen washer reservoir has stopped dumping its load onto the road. The headlamp washers still don't work and as I'm busy with so many other things I've decided to save that little job until the drier, warmer weather comes.
The Monzta
Old 02-03-2004, 12:11 PM
Same with me, I have no money left for winter tires so I rent garage for parking my baby during winter. Just take it every second weekend for a ride to circulate fluids :-(
I am working on these ... rear diff. bushings, it is really bad (no harm for car, but you should hear and feel what it is doing during ****ing:-(....). Subaru told me again, although it is piece of rubber and metal, I should buy new diff. No way, they are soooo greedy...:-)
Peter
Old 02-03-2004, 06:05 PM
The Monzta's Avatar
Subaru greedy? Tell me about it.
The Monzta
Old 02-04-2004, 07:08 PM
That's what I did a while ago and I haven't lost another clip since!
