Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 02-26-2008, 06:25 PM
Speedklix's Avatar
Locker Link Solution
just 12v 1156 bulbs, the install used replacement sockets for trailers, found em in a small autoparts store. You can also use replacement sockets/bulb holders for any car that uses 1156. Just drill the hole the size of the inner diameter, notch the "keyways" and install! A bit of high temp silicone (black of course) helps to weatherproof it and secure it in the hole.
hope that helps!
...the next step is to remove it
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
