Old 01-17-2004, 07:00 AM
pylon500's Avatar
pylon500 pylon500 is offline
the Flying Member
Send a message via AIM to pylon500 Send a message via Yahoo to pylon500 Send a message via Skype™ to pylon500
Want More Power?
Just a quick note of a link I found doing some of my 'aero' type stuff;
http://www.crossflow.com/products/fi...ts/CF6-33.html
These guys are talking about getting 360hp from our EJ33's (230 normally) with a light weight turbo installation
Awsome stuff, but you need to rob a Bank first!
arthur.
'80 DL 4x4 Wagon-White (gone)
'91 DL 4x4 Wagon-White (gone)
'92 SVX LSi Burgundy/Black with wing. (gone)
'04 Liberty B Spec 3.0R wagon-Silver
'02 Outback 2.5 wagon-White For Sale
I Don't Drive Fast, I Just Fly Low!!
I've moved to Taree , check out my progress at Picasaweb.
That's a 'V' in SVX dammit!
Old 01-20-2004, 07:24 AM
Thumbs up
Looks good.
It is easy for them to site the turbo and plumbing behind the engine, as there is no gearbox in the way.
I note they lower the compression ratio to 9.5 to 1, and in the turbo section they quote 6 to 8 lbs psi boost pressure, and give examples based on 7 lbs psi. Handy to know this as a target figure.
Anyone wishing to convert now knows we can get 320 to 350 hp with this c/r and 8lbs of boost.
This aero set-up would not be optimised as a road engine. Aero engines run at 80 to 100% revs all the time, so torque and flexibility at lower revs are less important. This one is probably gutless till the turbo spools up.
I also note, even though they describe intercooling, there is no intercooler in the illustration. It must be the lower spec engine.
Because of our engine bay tightness, I am still a fan of adding a small supercharger and intercooler, which because of linear boost will make up at low revs for the torque and power lost from reducing the C/R. The reduced C/R will also allow use of regular unleaded, though naturally the car will be drinking more of it due to increased power output.
Old 01-20-2004, 08:56 AM
mbtoloczko's Avatar
sans SVX
Yeah, the 2.5RS guys are getting about 260 bhp at 6-8 psi from their motors, so the EG33 should give about 340-350 bhp at the same psi. I've got a turbo calculator in my locker if you want to tinker with some numbers.
Mychailo
Visit my locker
Old 02-03-2004, 01:52 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Where is Graham when we need him?
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
