Old 09-09-2001, 10:47 AM
sk8ing19
Okay so I went out and got alittle crazy in the mountians last night. It must just have been that I was in manual mode the other day, because last night she sure did kick in when I need her to. The Light lit and the car took off like normal. So I would say all is fine.
Thanks
Old 09-09-2001, 11:33 AM
Powered up
That's good news Chris.
It is real easy to push on that Manual switch, and not realise it is on. Glad you did not have a problem.
Old 09-10-2001, 11:36 AM
svx_commuter's Avatar
Glad you found the problem.
When I first got my car I was always a little tenative with the throttle.
The power light never came on.
I had to learn to be fast with my foot to the floor.
Back to the drag strip?
Leave it in first gear.
The shift to second is a little higher than in power mode.
Automatic over-rev protection.
Old 09-10-2001, 11:52 AM
nvrmore100's Avatar
nvrmore100 nvrmore100 is offline
Send a message via AIM to nvrmore100 Send a message via Yahoo to nvrmore100
Originally posted by cocacola08
"Accellerate to ludicris speed"...Space Balls
What the heck was that....
Spaceball 1....
They've gone to plaid!!!
I love that movie.
Ryan
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter
http://www.ryanmacdonald.com
http://www.digitalvertigo.net
http://www.open-innovations.com
Old 09-10-2001, 11:55 AM
nvrmore100's Avatar
Thanks
Ok 2 things here.
First. If you want to try it out, do the resistor mod. It takes about as long as your signal removal took at the track. Just unplug it (right near the battery). It will always be in power mode after that...in case you are wondering.
Second. Why the heck didn't you call me!?!?! I could have used a little mountain run after spending all yesterday packing.
Ryan
Old 09-10-2001, 01:44 PM
Burn-up
If I was doing drag strip, I also would do this. But not too often.
Try it out and note what max revs it shifts on, and that it does it consistently.
If the over-rev protection circuit fails, which is possible, you will blow your engine. Even without blowing the engine, you will be stressing seals in the tranny.
But it's good fun though!!
Old 09-10-2001, 04:37 PM
dromano's Avatar
dromano dromano is offline
Originally posted by tober76b
speaking of 'mashing' the accelerator pedal, have any of you experienced the following:
after flooring it, once you've reached your desired speed (especially when it's below 45mph) and you let up a little so that you're around half throttle -- does your svx jump around a little bit trying to find the right gear? if i floor it, reach my speed and then completely let off the throttle then reapply to half throttle, it reacts fine (ie. finds the correct gear the first attempt-- smooth acceleration).
is this a characteristic trait of automatic transmissions? i've always driven a manual trans in the past.
thanks.
toby
This has happened to me in 5 different Subs, 3 Legacys and 2 SVXs.
A tech told me it is the throttle sensor, another electric marvel, we are not supposed to be so quick footed.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 09-13-2001, 02:19 AM
tober76b
at least it not a *problem* then.
thanks for the insight.
toby
Old 09-13-2001, 06:53 AM
cocacola08's Avatar
cocacola08 cocacola08 is offline
Send a message via ICQ to cocacola08 Send a message via AIM to cocacola08 Send a message via Yahoo to cocacola08
It's not the shift to second that I'm concerned about at the 1/4mi. Its the shift to 3rd, that takes you WAY out of the powerband, When I'm crossing the line, it's just starting to accell, in 3rd. It either needs to not shift to 3rd till after the line or shift much sooner so you can begin to gain more momentum in third. The best answer is not to shift to 3rd till after the line..
Kev
kevin.m.sheets@verizon.net
Old 09-26-2001, 12:19 PM
Lowered SVX
i am running with the resistor mod.
it does not leave your car in the power mode at all times. it makes the tranny shifts firmer. it basically take the coupe shifts away and allows the car to shift much more agressively and a lot less soft. i like it because it makes the car feel like it is launching out of first and second gear.
"Too much fun to drive!"
Old 09-26-2001, 12:27 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: i am running with the resistor mod.
The resistor mod allows full-time full line pressure by disabling duty solenoid A.
Randy Johnson
Mike Davis -- at Reading VI
Old 09-26-2001, 04:37 PM
ehyde111
Drawbacks to this mod??? Someone did this long term to a Nissan 240sx and claimed it demolished their tranny. Is that what the previous post that said it stresses seals was referring to?
