View Poll Results: Which way have you installed your transmission cooler?
Series (before original cooler) 3 7.32%
Series (after original cooler) 5 12.20%
Parallel 3 7.32%
Bypassed Stock 9 21.95%
Don't have a tranny cooler yet. 19 46.34%
Some other way not listed. 2 4.88%
Voters: 41. You may not vote on this poll
Old 08-18-2001, 04:40 PM
dromano's Avatar
dromano dromano is offline
Cool trans fluid filter
I'm replacing the fluid filter from Subaru with a Perma Cool unit that has a spin on filter. Perma Cool kit cost 31.99 + 8.74 S&H from Jeg's in Ohio.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 08-18-2001, 04:48 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Guys,
does a 94 need another cooler? I know the 92/3 were a bit shakey (no offense)... but I heard that 94+ have been changed.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 08-19-2001, 12:30 AM
htyei's Avatar
htyei htyei is offline
SVX Animated Icon Guy!
Send a message via ICQ to htyei Send a message via AIM to htyei Send a message via Yahoo to htyei
install tranny cooler
Mines not listed
I installed my cooler(s) in series with the oem tranny cooler
One 19k gwv b&m in series after and one 19k gwv b&m in series before.
I think I have the updated radiator, but I am not sure (former owner had the radiator replaced, I think, hopefully with a newer one)
Having my temp sender unit after all the coolers, my temperatures never go past 163.
My only worry is too much distance for atf to cover, and maybe the temperatures are actually too low for the tranny.
I maybe remove the oem cooler from the loop to see what happens to the temps later in the summer.
Henry Yei
htyei@svxwrx.com
1992 Dark Teal LS-L w/o spoiler "OLIVIA"
http://www.svxwrx.com
Old 08-19-2001, 06:25 AM
ehyde111
Re: install tranny cooler
Originally posted by htyei
Mines not listed
Just curious, why 2 aftermarket coolers?
Old 08-19-2001, 08:21 AM
picklesbitch
Mines not listed
If your stock cooler plugs up, you won't have any cooling for you trans. with the coolers in series.
Old 08-19-2001, 11:49 AM
htyei's Avatar
plugging up
I know, however i think a have an updated radiator, I thiink....
Why two coolers? actually the second one was supposed to be for my oil cooler( i do some autocross, so the stress is higher)
Unfortunately, I didnt research the idea very througly and could not find a path to put the cooler for the engine oil.
My plan was to put each cooler on either side in front of the condensor for a perfect fit and match.
What to do with the second cooler? I was thinking of selling it on this board, but I ended up using some of the fittings from the second cooler to create a custom fitting for the temperature sender.
The reason I put it in series was mostly because it is easier, I didnt have the parts for parallel and I was sure it would pump anything to the cooler in front of the condensor because of the varying in height.
Instead I mounted the second one parallel to the ground in front of the oil pan. and the first in front of the condensor.
Of course this wrecks havac on how much atf I need int he system. WHen the car hasnt started up, it looks way over ful, but when i start the car and it starts pumping it goes to the correct height on the dipstick.
Henry Yei
htyei@svxwrx.com
Old 08-19-2001, 10:40 PM
wasions's Avatar
wasions wasions is offline
SVX Black Belt Master
I'm waiting for an answer to Seraphims question. Does a '94, or newer, need a filter/cooler?
I had my ATF pumped out and refilled at 100,000 miles, and the tech said everything looked great. (Granted, my autocross days were over in the 80's.)
Steve
Steve
'95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten)
'02 Outback LLBean, 56K
'02 Black Sapphire Volvo V40, 133K - "Shadowfax"
'06 Triumph Tiger, 19K
'99 Suzuki DR350SE, 8.5K - "Geezer Killer"
Old 08-19-2001, 10:54 PM
dromano's Avatar
Smile cooler in front of condenser
Any precautions regarding the condenser to install a cooler in front of it?
Old 08-20-2001, 08:42 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Steve
Someone more knowledgeble than me (and there are many) might field this one later, but, it's my undestanding that, in the '92, '93 model year SVXes, there was a screen at the inlet to the cooler that kept getting clogged. The updated radiator took care of this problem, so, supposedly, no, you wouldn't need an external cooler. However, if I owned a newer model SVX, I would consider it "cheap insurance." Not only would I do the cooler, but, I'd buy the 92 program filter kit and install it. Another "cheap insurance" move. But, that's just me.
Randy Johnson
Mike Davis -- at Reading VI
Old 08-20-2001, 01:34 PM
htyei's Avatar
yes, considering the previous owner replaced the radiator in 1999
but had to fix the tranny in 2000, i'd rather install a 100 dollar part rather than pay the 4500 for a new tranny
Henry Yei
htyei@svxwrx.com
Old 08-24-2001, 03:55 PM
svx_commuter's Avatar
I have mine installed after the radiatior and in front of the a/c condenser. The temperature out the trans drops about 30F, 15F in each one. The thermometers are attached to the outside of the metal trans lines and wrapped with foam insulation.
At first I had it in between the condenser and the radiator and by-passed the radiator all together. This got way to hot on hot days very fast!
I have also installed a diverter valve to bypass the cooler in the winter.
Now all I have to do is get the AWD system to work and find out where to put the "secret hole" in that hydraulic control valve thing and the car will be in great shape.
Old 10-17-2002, 11:22 AM
