Old 06-21-2003, 06:13 AM
Jamsvx's Avatar
Jamsvx Jamsvx is offline
Send a message via ICQ to Jamsvx Send a message via Yahoo to Jamsvx
SVX Self Test Codes
This is around on this site too but just saw it reposted on the *otherclubsitethatcannotbenamed* so credit to blroth:
The "Power" light indicates transmission codes. The following self
diagnosis will show any fault codes for the transmission.
To perform the self diagnostic test for EXISTING problems
1) Warm up engine by driving at speeds greater than 12mph.
2) Stop vehicle and turn ignition switch OFF.
3) Turn ignition switch ON and make sure POWER indicator lamp comes
on.
4) Turn ignition switch OFF.
5) Move selector lever to D and turn manual switch ON.
6) Turn ignition switch ON.
7) Move selector lever to "3" and turn manual switch OFF.
8) Move selector level to "2" and turn manual switch ON.
9) Move selector lever to "1" and turn manual switch OFF.
10) Partially depress accelerator pedal (to turn idle switch off).
11) Check code as displayed on POWER light. Blinking once every
1/4sec is normal.
To perform the self diagnostic test for PREVIOUS problems
on.
5) Move selector lever to "1" and turn manual switch ON.
7) Move selector lever to "2" and turn manual switch OFF.
8) Move selector lever to "3" and turn manual switch ON.
9) Move selector lever to "D" and turn manual switch OFF.
1/4sec is normal.
Trouble codes:
11 Duty solenoid A
12 Duty solenoid B
13 Shift solenoid 3
14 Shift solenoid 2
15 Shift solenoid 1
21 ATF temp sensor
22 Atmospheric sensor
23 Engine revolution signal
24 Duty solenoid C
25 Engine torque control signal
31 Throttle sensor
32 Vehicle speed sensor 1
33 Vehicle speed sensor 2
James
1992 charcoal grey SVX:
27 August 2002 to 27 January 2004 - she will be missed
Was back in Sydney for a while but not hot enough so now in Dubai! Has it been that long since I owned SVX-33H!
