speedometer
odometer working..speedometer NOT working ?
Re: speedometer not working
Carl,
I will check in the USA service manuals tonight, I am sure this has been noted before? Anyone.... Also edit your title to make more like mine....
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: speedometer
Got the same problem with mine. It started after I had a new trany installed. The car sat for three years before the install, I suppose the down time could have affected the speedometer.
[SIGPIC][/SIGPIC]Kenyatta The farther backward you can look, the farther forward you are likely to see. -Winston Churchill My baby: 94 lsi My fast baby: 2001 Suzuki Marauder My new baby: 2010 Subaru Outback |
Re: speedometer
speedo not working at all or not working above 50kph ?
Re: speedometer
sometimes speedo sticks at 10 kms and sometimes nothing...carl
Re: speedometer
vehicle has been stored for 8 years.
Thread Tools | |
Display Modes | Rate This Thread |
