Disk-O-Thique
FYI
Just had my car serviced, and put on two front s/h disks from a low mileage crashed SVX, about 38k miles from memory. My car now has about 87K miles on, and my own disks were not too bad but developed a shimmy at motorway speeds especially after heating up. The s/h ones were not worn very much, and I had them lightly skimmed before fitting. They were extraordinarily bad on the car, would not surprise me if they contributed to the accident and writeoff. However, on advice from Beav, who is ever knowledgeable and helpful, I had the garage take them off again, and clean the hub and the bell housing behind the mounting face, where the disk aligns with the hub. Major major difference. The car has now no shake or judder at slow traffic speeds. There is still a bad shake at motorway speeds, and the left one is the culprit. I will be having the disks shaved on the car this week to rectify. Anyway, the point is, if you have to have your disks off for any reason, make sure the mechanic does two things; first note exactly how they were oriented, and put them back exactly the same and on the same wheels. Secondly, be aware that any dirt or rust flakes that get between the back of the disk and the front flange of the hub will cause serious shimmy, or run-out as our US friends call it. Even putting on new disks, it would be wise to go for Operating Theatre cleanliness standards. Please file under: Lessons Learnt the Hard Way Joe
Thanks a lot for the tip Joe, I will be doing mine soon.
For those not able so get S/H, try the following links http://shop.potn.co.uk/product_info....ducts_id/41991 http://shop.potn.co.uk/product_info....ducts_id/42494 http://shop.potn.co.uk/product_info....ducts_id/43491 http://shop.potn.co.uk/product_info....ducts_id/43994 Should do me fine. Andy |
Looks good
Thanks for the links Andy.
They look pretty good. I have seen posts on the US site about replacement disks.[Or rotors as they like to call them] From memory, some have said don't get the drilled ones, they warp quicker. Others say the grooved ones cause a howl or whine as the edge of the groove passes the pads. My choice would be a 10-groove, no drilling. Is this price, £124, for one disk or two? Joe
Black Betty [Bam a Lam!] '93 UK spec, still languishing Betty Jersey Girl Silver '92 UK [Channel Isles] 40K Jersey Girl @ Mersea Candy Purple Honda Blackbird Plum Dangerous White X2 RVR Mitsubishi 1800GDI. Vantastic 40,000 miles Jersey Girl Last edited by svxistentialist; 10-28-2002 at 03:09 AM. |
I have a friend with a Porche, fitted with drilled and grooved. After about 20k miles, he says that he has had no noise from them at all.
I believe that the prices quoted are per pair. Andy PS have you rechecked the link you sent me? |
