Old 04-30-2010, 07:17 AM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
2002 WRX 5MT transmission complete swap kit - $800
Ladies and germs,
I was planning to buy this 2002 WRX 5MT and put in my new acquisition (94 Pearl). But, wife has convinced me that I should stick with the Auto box in this case.
This includes the trans, all sendors/speedo still connected, Clutch master & slave cylinders, Pedal assembly, flywheel & bolts, pressure plate & clutch, all shift linkage and shifter, trans cross member. It does not include a drive shaft. you will not need a rear end or gears as the 2002 WRX has the same rear diff as the SVX, 3.454.
I asked for the trans model # to find out if it has the newer RA gearset but he could not find the Trans model #. Honestly, I did not care as I've been driving an older (non-RA) 2002 WRX 5MT for over two years with no issues.
Anyway, the parts are located near Charlotte NC. Here is the link to the CL add. I'm going to tell him I posted this since I decided not to buy. Good luck.
Link to Craigslist add
http://columbia.craigslist.org/pts/1710853902.html
Picture he sent me of the parts
http://www.subaru-svx.net/photopost/...ze=big&cat=500
Txs,
Marc
Old 04-30-2010, 11:04 AM
svxpert svxpert is offline
Re: 2002 WRX 5MT transmission complete swap kit - $800
<< asked for the trans model # to find out if it has the newer RA gearset but he could not find the Trans model #. Honestly, I did not care as I've been driving an older (non-RA) 2002 WRX 5MT for over two years with no issues. >>
cant see the trans code huh? i see it in one of the pics. thats wierd...
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 04-30-2010, 12:47 PM
svxcuseme's Avatar
5 speed 4 sure
Good point svxpert. I see where you are going with this. I sent the message below to the seller. Let's see what he comes back with.
Your skepticism brings up a good point. I would not recommend anyone try to purchase this and have it shipped. I would never do that personally. My interest was only in supplying info for someone interested in a local pickup. I should have mentioned this from the start.
"Alex,
After I posted this, I had a comment that the trans code I was looking for is on top on that sticker close to where the starter would be. you can see it in the picture you sent. Can you read it?
thanks,
Marc"
Old 05-03-2010, 02:23 PM
svxcuseme's Avatar
5 speed 4 sure
The sticker says: 664943
