Old 08-26-2002, 11:08 PM
petesvx2's Avatar
petesvx2 petesvx2 is offline
help before i break it
can someone tell me approx. where to put the jack stands after jacking the front of the car up? also where is a good jack point. i want to take the resonator out of the fender and i need to get the wheel off to do so. any help would be appreciated.
ps. i searched the archive with no luck
1992 Pearlie ... ??????k Sold 8/04
Kenwood KDC-MPV619
Wedgie Cupholder
1998 Acura Integra LS 74k Sold 1/07
2007 Toyota Tacoma Prerunner SR5 .04k!
2011 Toyota Tacoma Double Cab, 4x4 TRD Sport
Old 08-26-2002, 11:13 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
If you are using that whimpy thing they gave you, there are marking under the car. Look underneath. Also in the manual.
If you want a lift, there are beams under the car that the beams can go. You can easily tell where they are. If you hear any crunching sound, you are too late.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 08-26-2002, 11:25 PM
petesvx2's Avatar
well i was gonna jack up one side, put in a jack stand, then jack up the other side, and put the other jack stand in, then take the wheel off...i'll be using a hydraulic floor jack type thing, you pump w/ your hand and it goes up you know...so where do i put the stands? is there a slot or something
Kenwood KDC-MPV619
Wedgie Cupholder
Old 08-27-2002, 11:38 AM
lee lee is offline
if yyou're only working that one corner, put the jack at the same place you would for the flat-tire jack. Then put a jackstand under the frame part where it attaches the lower A-arm. Let the jack down slowly so you know the stand isn't going on vacation anytime soon with you under there, then pull the wheel.
Old 08-27-2002, 02:55 PM
I_Alcyone_I
I put mine up with a floor jack where the body bolts onto the frame, right behind the front wheel, under the door. I didnt have any problems that way.
I started carrying a floor jack after I broke the crappy spare tire jack.
Old 08-27-2002, 09:58 PM
petesvx2's Avatar
i used that bolt also when i got a flat, but how do i get the jack there, and then move it away to put the stand under
Kenwood KDC-MPV619
Wedgie Cupholder
Old 08-27-2002, 10:12 PM
I_Alcyone_I
Sorry, I dont know. I left the floor jack there while I did the work.
Old 08-27-2002, 10:22 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
According to the FSM, the safety stands should be put where the trunk jack would normally go when jacking the car, that is, along the "edge", instead of on the frame.
They also suggest jacking it at the crossmember in the front, and on the diff in the rear, but my floor jack won't reach in that deep, so I usually jack on the frame, and put the stands at the "edge" of the car.
I can scan the FSM if it'll help anyone.
VK
Old 08-27-2002, 11:27 PM
petesvx2's Avatar
that would be really helpful, please do if you dont mind
Kenwood KDC-MPV619
Wedgie Cupholder
Old 08-28-2002, 08:39 AM
vkykam's Avatar
Et Voila!
http://www.subaru-svx.net/photos/user.php?vkykam|4206
It's a mulit-page TIF file, so if your browser can't open it, download it and use the Imaging utility that comes with Windows to open it up (assuming you're a PC guy, of course).
VK
Old 08-28-2002, 01:46 PM
petesvx2's Avatar
do you by chance have a similar picture file like the one you scanned but for jack points for the front end of the car?
Kenwood KDC-MPV619
Wedgie Cupholder
Old 08-28-2002, 04:34 PM
vkykam's Avatar
It's all there. It's a 2 page TIF, so if you only see one page, you'll have to use another program.
Included is the front jack point (crossmember), rear jack point (diff), and jack stands/hoist positions.
VK
Old 08-28-2002, 07:57 PM
petesvx2's Avatar
i cant figure out how to get the 2nd page up
Kenwood KDC-MPV619
Wedgie Cupholder
Old 08-29-2002, 10:12 PM
vkykam's Avatar
I've separated it into 2 TIF's. Check my locker.
VK
Old 09-01-2002, 12:15 AM
petesvx2's Avatar
thanks a lot bud
Kenwood KDC-MPV619
Wedgie Cupholder
