Steering Wheel Woes
So does the SVX steering wheel only have one position other then telescopic? Is there a mod someone has so it isnt so low?? The steering wheel sits on my theighs
Thank you for any help provided |
Yes. Look under the steering column and you should see another lever. That will set it for you so you can tilt it. Once you set it , that will be the same position every time you pull it down.
Paul 1969 Corvette 1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS! 1995 Corolla 2003 Highlander |
Thank you all |
just lie down with the back of your head on the floormat, looking up at the bottom of the steering wheel, you'll see it, along with a little lever that will let you eject the key if the gear selector is stuck in something besides 'P'.
There are three levers, the telescoper, the memory lifter, and the up/down lever, the latter being under the steering wheel. My PO wasn't aware of this one
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
OK I am at work so I cannot give you pictures but if my memory serves me here are the locations: "picture this" the steering column, on the left there is a lever that I think says up/down? It is the lever that you use to get out of the car. When you lift on that lever it should move the wheel up. So if I am correct when you get back in the car and pull down on tthe wheel it goes all the way down to your lap? Then there is another lever on the left under the column that allows you to telescope the wheel. Now there is one more lever. It is under the column, to the "right" of these levers closest to the dashboard. Get in the car and with the wheel all the way up( like it would be when you go to get out of the car), now pull that lever nearest the dashboard( I believe it goes towards you) and push down on the steering to a spot that is comfortable for you ( it should click into many positions) and that is your setting so now everytime you get out of the car and release the up/down lever and then get back in and pull down on the steering it will "remember" the setting.
All of you are awesome on this form thank you so much As you know Im new to the form also a new SVX owner (finally found one muahahahaha) So yeah Ill be asking random questions from time to time thank you all again and one day I hope to meet someone else with a SVX
Thx for the resolution |
