Old 07-17-2005, 11:34 AM
kuroneko_sama's Avatar
kuroneko_sama kuroneko_sama is offline
aka sir_romeo
Send a message via MSN to kuroneko_sama Send a message via Yahoo to kuroneko_sama
Question trim/dash removal
i am going to install reverse glow guages, and you are all quite informative on how to do that...thanks.... but the question i am having the hardest time finding an answer to is.... HOW DO I GET TO THE GUAGES WITHOUT DESTROYING MY DASHBOARD!!!!!!
ive attempted and stopped before i made a mistake that would break my trim.... if anyone has a step by step on how to get to the guage cluster without killing my car, it would be much appreciated.... photos would be nice too, or some schematic.
I Leave late and STILL manage to arrive early
Car #26..'97 SVX Silver (120k and climbing)
previous SVXi:
Car #24..'94 SVX Ebony 216k (sold)
car #18..'97 SVX LSI "Ebby" Pearl 175k (sold)
car #19..'97 SVX LSI Brilliant Red 103k (sold)
car #14..'92 SVX Claret LS-L Touring (sold)
car #13..'94 SVX Laguna Blue LS (sold)
Old 07-17-2005, 08:08 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
there are 2 screws under the alarm/foglight switchs and 2 under the hazard/defrost switches. then there are 2 or 3 screws under the rim of the dash. unplug the switch assemblies for the foglight/alarm and the hazard/defrost switch and remove the switches. the whole trim panel will then be able to be removed and once you get it out a little you can unplug the clock and then set the trim panel aside out of the way. next remove the clear lense over the gauges. where you wire them in is up to you but i used a wire i found that goes to the alarm/foglights/cruise switch that shows power only with the lights on and i used one of the bolts that holds the panel on underneath the steering column for a ground. the bolts for that panel are one behind the change tray and one behind the parking light/heated mirror switch. let me know if you need to know anything else. good luck
Old 07-17-2005, 09:35 PM
aka sir_romeo
how do i get to the screws near the parking light and defroster switches?
previous SVXi:
Old 07-17-2005, 09:41 PM
Budfreak's Avatar
Banned
carefully pry the switches out with a small flat screwdriver.the screws are behind the switches.
Old 07-17-2005, 11:15 PM
aka sir_romeo
so those 2 button pannel thingys on each side of the wheel just "pop" out?
previous SVXi:
Old 07-18-2005, 01:24 AM
Budfreak's Avatar
Banned
yes they just pop out. just use care when doing it and all will go well.
Old 07-18-2005, 04:28 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
When you get finished removing the 6 screws holding the dash cluster, make sure the steering wheel is in the lowest tilt position. Carefully pull the dash cluster out towards you just enough to feel it let loose from the 3 plug harness....then tilt the top of the cluster towards you and remove the cluster sideways towards the center counsel.
1995 Subaru Svx L / AWD
Old 07-18-2005, 07:26 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
One word: SEARCH
search for my name with dash removal. There was a PDF attachement that will teach you how to remove the dash.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 07-18-2005, 09:53 PM
aka sir_romeo
found it... thanks a bunch... now i just need to find laguna blue pearl to paint up the plastic front piece to match the exterior
previous SVXi:
