Cleaned my valve covers...
Up to last weekend, it was pointless to really clean my engine as I had front seals that were leaking oil at a steady rate. All of that changed last weekend when I drove to NJ and had my front seals & timing belt replaced by Tomssvx. Big thanks!
As my car has 118K miles on it, the exterior of my engine (save the intake manifold) has gotten pretty oily over the years. Decided to spend a couple hours today cleaning my valve covers which were especially nasty... I removed the airbox and battery as if preparing for a sparkplug swap: Using rags and a powerful degreaser, I went at the valve covers for 1.5 hours, and while they're not perfect, you can clearly see their silver color shining through! I also used the opportunity to clean my fenders underneath the airbox and battery... Also spent another hour cleaning my throttle bodies and other areas on my engine that have accumulated grime over the years. The final result? -Chike P.S. I know...I know...they're support groups for people like me!
nice where did u get front seals from
1992 pearl svx (given away) Custom Cold Air Intake Stage1 Shift Kit Brembo Cross-Drilled/ Slotted Rotors. Front and Rear 4.44 gears now in better hands of svxfiles |
Tom picked up some seals from Napa. The timing belt, thermostat, and radiator hoses that we also replaced were from Subaru. I'm now able to run Mobil 1 synthetic with not a single drip of oil! -Chike
cool thanks
Chike,
Missed a spot! -Bill p.s. what degreaser did you use?
-Chike
Pics look good. I love your STi oil cap very much...
Nice and clean. No more dripping... Any pics on changing seals and timing belt stuff? Did you change your water pump as well?
Isn't grease lightning degreaser harmful on aluminum? That's what I read on it's label.
We inspected the water pump, and it looked good. -Chike
What I use
I use tire cleaner to keep everything under the hood clean. It couldn't be easier - you just spray it on and walk away (I come back and hose off the painted areas about 10 minutes later). It cleans everything.
If oil has built up you may have to take a brush to it. On a really dirty engine you may have to apply it two or three times. But once it's clean it'll stay clean for longer too. I've tried a few brands but found that TurtleWax Wet'n'Black works best for me. Last edited by bcpianoman; 07-16-2005 at 11:34 PM. |
Thanks for pointing that out. Didn't even cross my mind at the autoparts store! -Chike P.S. Forgot to mention, when I was done, I sprayed my valve covers with brake parts cleaner. That should have removed any residue left from the GL...
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 07-16-2005 at 11:36 PM. |
I went to Greased Lightning's website and read the FAQ for their products: http://www.greased-lightning.com/products/faqs.html#1f In regards to using GL on aluminum they noted: "Can I use Greased Lightning Multipurpose on metals? Greased Lightning products are recommended for use on most metals except aluminum or an aluminum alloy. Greased Lightning will leave a cloudy appearance on aluminum. However, this does not apply to aluminum siding with a factory baked-on finish." Phew! I didn't notice any 'cloudiness' on the metal, but I did finish up the job by spraying evaporative brake parts cleaner on everything... -Chike
Oh my...
On GL's automotive website they have a place to cast your vote for your favorite GL model...
Kaylee got my vote! -Chike (hijacked my own thread! )
YESSSSSSSSSSSSSSSS I love waking up to that!
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
