Old 07-05-2005, 08:03 AM
djsiva's Avatar
djsiva djsiva is offline
Send a message via AIM to djsiva
clunk in the rear end
I recently had the tranny rebuilt and installed a used rear differential and had all new gears put in the front differential. Along with this, I also installed a shift kit to firm up the auto trans. Since then, when I get on it from a dead stop, usually while turning at the same time, I get a loud clunk in the rear end. From everything I have read, I think it's rear wheel binding and have seen some people on here use the Brad Penn LSD additive to correct it. I want to try to confirm this before I use it. Also, I now have my POWER light blinking 2x per second for 8 seconds on startup. The scanner at the transmission place showed nothing wrong. I took it to my friend at Subaru to hook it up to their scanner and it showed vehicle speed sensor 1 and 2 (my speedometer still works) and a line pressure duty solenoid C. I don't know if this is due to the increased pressure from the shift kit or if I have something going wrong in my new tranny. If anyone could provide some insight to this, it would be greatly appreciated.
Thanks...
Old 07-05-2005, 09:52 AM
ThetaReactor
A problem with Solenoid C can cause the rear wheels to bind like that. Run a quick search, it's a well-documented issue.
Old 07-05-2005, 10:10 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Binding is more of a trembling vibration, not a single clunk. A clunk is usually a diff mount bushing.
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
