Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 06-26-2005, 09:25 PM
kuoh kuoh is offline
The VF(typ) indicates the typical voltage drop across the LED, VF(max) indicates maximum voltage drop before damage occurs. With a current limiting resistor, an LED will operate at VF(typ) with the resistor dropping the rest of the system voltage. This means that you should calculate your current with an LED voltage of about 2.2V, though the ambers actually operate at 1.95V.
I wouldn't bother with calculating the values with a system voltage of 10.2V, since that is not a normal condition and you have more problems to worry about than the LEDs not being bright enough. I would use a low end of 11.5V and don't forget that the isolating diode drops an extra 0.7V, which is not factored in on that webform. You can comphensate for this by adding 0.7V to the system voltage when using their formula.
The problem in your current circuit is that at 13.2V, the LEDs are still dropping only 2.2V, not 3.1V as you're assuming. This means that you're actually running 79ma through each LED. If I were you, I would change out those resistors ASAP, as those are some expensive LEDs if you end up having to replace a bunch of them in the near future.
KuoH
Old 06-26-2005, 10:28 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Thumbs up
Been busy at work. I still have to mail you the title for the SVX. Now, it's my turn.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 06-26-2005, 10:29 PM
Seraph's Avatar
Originally Posted by ThetaReactor
BG Micro has some excellent deals on LEDs, by the way...
And I'm sure you've come across these monsters:
http://www.luxeonstar.com/
A friend of mine put in a blue one as the dome light on his Jetta. It was not something you wished to turn on without warning.
Luxeonstars -- Yeah I know of them. They are the same ones the new Audis use for the front head lights. They are nice. Enough said without giving away too much.
Current SVX: NONE
Old 06-26-2005, 10:31 PM
Seraph's Avatar
Originally Posted by SilverSpear
just an idea guys, i think you have junk yards in the states, right? and you do have damaged cars with led taillights, right?... so why don't someone go and get a bundle of broken led taillights and do the conversion without taking that expensive road...
Because they are had to find (LED Junkers) and also, they are very exensive
Current SVX: NONE
