Old 07-29-2004, 10:41 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
Oxygen Sensor Removal
Its time to replace the oxygen sensors. I know a lot of other people have replaced theirs by themselves. I've never removed these sensor on any car before. Can anyone give me a little how-to on how to remove the sensors? Anything I should look out for? I'm buying new sensors from www.oxygensensors.com.
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 07-30-2004, 05:51 AM
michael's Avatar
michael michael is offline
What Potholes ???
Not to hard, just get some PB Blaster spray it on the old o2 sensors and let it soak overnight. Give it a good soaking and a little heat helps, mabey take it for a spin before you remove them or a propane torch works well. Make sure you use the correct size wrench and when you put the new ones in clean the rust out of the threads and coat them with anti-seize lube. Be careful not to get it in the sensor, just on the threads. When you put the new ones in don't plug the wire back in until you have tightened the sensor down, it prevents the wires from twisting up.
P.S. Do not over tighten or cross thread, finger tighten them first.
Wanted: Steering Wheel
Old 07-30-2004, 05:58 AM
michael's Avatar
What Potholes ???
I forgot to mention the plugs for the wires, they are a little tough to un do. You can do this from the top of the engine, they are on the left and right sides of the back of the engine.
Old 07-30-2004, 12:29 PM
BigBlueSVX's Avatar
thanks
thanks for the info! The SVX should be running well again in days.
My Cardomain page
Old 08-01-2004, 07:02 PM
svx_commuter's Avatar
I use a small flat head screw driver to unlock the O2 connectors. the "tang" has to be moved out for release. I find these connectors to be very time consumming and difficult even after having taken them off several times and other suby's too. Sometimes 2 minutes and other times 20 minutes. It must be me.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 08-02-2004, 05:47 AM
michael's Avatar
What Potholes ???
I'ts not you, they suck! One push down tab would be sufficient.
Old 08-02-2004, 08:32 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
That's odd.
When I removed mine, each of the three wires from the sensor had a separate little bullet connector which clicked into a plastic housing. It was quite easy to remove them, however reconnection was tricky because they could potentially be connected in the wrong order.
I found it difficult to connect the wires with the sensors installed because isn't much slack. It's much easier to connect the wires first, then twist up them up anti-clockwise so that they untwist as you screw in the sensor.
Old 08-02-2004, 11:14 AM
michael's Avatar
What Potholes ???
You proably have universal o2 sensors.
Old 08-02-2004, 05:11 PM
an959
Hi all
i just jointed this forum and here is my first post.
get this special tool from sears, it will save you alots of time.
http://www.sears.com/sr/javasr/produ...id=00947079000
Old 08-02-2004, 09:11 PM
BigBlueSVX's Avatar
Finished
Its done! The new sensors are in place and the car is running great. Thanks for all the help. Now I have to go through another tank to see how my gas mileage is.
My Cardomain page
Old 08-05-2004, 06:58 PM
anyone know the metric size wrench to use to remove the oxygen sensors? Thanks Chris
