Iris
If the IRIS valve wasn't working (i.e., stuck in full open/closed or somewhere in between) How would you tell? Would it set off an error code? Or would the horrible performance be enough to tell? Thanks.
-Mike '92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91 "It says here, 'Breakfast any time'... That's right... In that case, I'll have the pancakes in the Age of Enlightenment..." |
Re: Iris
If the IRIS valve was stuck closed, there would be good acceleration up to 4000 rpm, then the engine would run flat from there with little torque. If it was stuck open, it would be gutless below 4000 rpm, but run hard above 4000 rpm. It is not known to give trouble, but there is allways a first. What problems are you having? Harvey.
Re: Re: Iris
I suppose you could unplug the vacuum line to it and find out.
Re: Re: Re: Iris
Stuck closed at higher rpm, the resonate inlet pipes could not induct a full cylinder of air, from one side, it needs both sides to be joined, to provide enough chamber volume to supply the air in the time available. Harvey.
Thanks for the replies. I'm not having a problem, but I think I was trying to ask what Pockets asked. Kinda, whats the potential for a bunch of us driving around with non-functioning butterfly valves and never even knowing it?
Thread Tools | |
Display Modes | |
