Old 07-19-2004, 09:25 PM
svxgirl92
is it the belts????
Alright, here's the deal, whenever i'm idling i hear a squeling from under the hood. I'm assuming it's the belt. I just had all of the belts replaced less then a year ago, and the noise just starting the other day. It only does it when i am not excelerating. If i touch the gas at all, it stops. What do i do? and should i be worried????
~Jamie
92 SVX Ls pearlie
Old 07-19-2004, 10:25 PM
SubaSteevo's Avatar
No longer blue member
1. Check both belts (A/C and PS) to see if they are cracked or worn.
2. Make sure both belts are tightened correctly.
3. Try to locate the source of the sound, could be that a bearing in one of the pulleys is going/went.
-Steve
01' MSM Lexus IS300
Old 07-19-2004, 10:40 PM
The AC electric clutch will make that noise when it is going out as well.
Old 07-20-2004, 12:04 AM
svxgirl92
entire A/C system was just replaced last year too. Although is has only been 1 year since i replaced the belts, i have put 30k miles on the car, so i wouldn't doubt that that's what it is...thanks for ya'lls help
Old 07-20-2004, 05:42 AM
n00b on demand's Avatar
try adding some power steering fluid...i had this squealing noise thats the same as yours and it went away after i added some fluid. Weird fix i know but hey it worked.
Old 07-20-2004, 06:54 AM
dcarrb dcarrb is offline
Originally posted by BurgundyBeast
...could be that a bearing in one of the pulleys is going/went.
Yes, with relatively new belts and AC, I'd keep an eye (or, um... ear) on the pulleys. They can and will seize. A mechanic with a stethoscope can tell you for certain if one is circling the drain.
dcb
Old 07-20-2004, 09:23 AM
Earthworm's Avatar
Meow!
Also check if the crank pulley hasn't separated and causing the noise. Are the belts dry/clean?
Old 07-20-2004, 08:52 PM
svxgirl92
yeah, everything under my hood is clean, i get bored and clean my car at random. As far is being dry, i have no clue, i'm thinking its a pulley, but i'm going to take it in in the next couple days. thx!
Old 07-20-2004, 09:57 PM
UniqueAngle
This may sound silly to some, but even something as simple as the brand of belt may be to blame - not all belts are created equally.
I've found that the DAYCO belts on my '62 Corvair are more likely to get thrown off the pulleys then any other brand (they're actually a tiny bit wider & don't sit in the groove as well).
The Dayco's would also shread on my last car, a Dodge Stealth, where all pulleys checked fine. Could easily be a similar issue here.
Dayco's are usually in a black/grey package
Kelley-Springfield in a green/white package
not sure about the other brands.
Hope it helps.
~Brenda
