Doh... now the dust shield...
Okay... I began reassembling my front hub again last night after I'd finally managed to get the old bearing out and the new one installed. Anyway... got as far as installing the hub and pushing the axle back through the housing and.... DOH!!! There's the dust shield I took off to make it easier to get my tools in there.
Now, I'm usually one who says that if it's supposed to be on there, reinstall it. What's the opinion of the "jury". Should I press my hub back out again so I can reinstall the dust shield, or should I just forego it? What would be the impact of leaving it off? Input appreciated! |
I don't remember that ever coming up. A quick search came up with instructions on removing the dust shield because it was rubbing on the rotor on sharp turns.
I'm going to assume that without the shield you're going to see a lot of brake dust collecting on your suspension components. I'm not sure if the dust can get into anything to cause damage. Now that I think of it I believe I have a rotor rubbing the dust shield on one corner. I'll have to take a look at that.
I dunno if that's a positive or a negative there old chum
I've done some searching, and there are other cars out there (Subarus) where many advise that if you're not rallying your sooby then you can take the heat shield off with almost zero impact. Myself I'm still of two minds; I mean I realize the cooling would be better, but you're right that dust might get up into the suspension components. On the flip side, on inspection it doesn't look like the dust shield had any accumulation of dust, or nicks from debris. <sigh> Well, unless I can find a good way to get it back on without removing the hub, I think I'm gonna leave it off... just too much work and I don't want to run the risk of the bearing race coming out and picking up dirt before I put it all back together. Anyone else any input before I call this one? |
Leave the dust shield off. Now you can actually look forward to an early bearing failure as an excuse to put it back on. With a secret bearing death-wish, the bearing will now last until 2015.
Ron (Will duct tape help?)
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Lots of cars that i have worked on in michigan have had there dust shield rusted off. I rember sport compact car with project WRX had to take theres off in the front for some reason, and there rotors complety filled up with rocks and dirt, but then again they probely were doing rally stuff.
Anyone any method of getting it on under the tone wheel? That seems to be the sticking point. At the moment the best I can come up with is to use my cutoff tool to cut the center out of the dust shield... basically getting rid of the "lip" that won't fit behind the tone wheel. Anyone? And no, duct tape won't help <grin> |
Me thinks you misunderstood Gavin
He was saying above that you can look forward to your bearing going bad again so you have a reason to pull the hub apart, hence you would have a reason to put the dust cover back on.
He's also saying that with a secret bearing death wish that with your luck the bearing will last forever and you'll never get a chance to put the dust sheild back on. You Europeans are so funny Talk at you later mi amigo. ~Ray PS. I leave tomorrow morning to pick up the new SVX...what are you doing next weekend....maybe i'll drive it over there for you to check out
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
Thread Tools | |
Display Modes | |
