Old 05-28-2004, 05:33 AM
Originally posted by awdrocket92
this guy is running 1/4 miles with only crank and alternator!!! ok, who needs p/s for the 1/4 mile? i don't, so the engine as that less load to work. but who runs 1/4 miles with no water pump? that is ridicules...
FYI...The SVX water pump runs off the Timing Belt, not the Accec. belt....
Old 05-28-2004, 09:25 AM
svxsubaru1's Avatar
svxsubaru1 svxsubaru1 is offline
this guy is running 1/4 miles with only crank and alternator!!! ok, who needs p/s for the 1/4 mile? i don't, so the engine as that less load to work. but who runs 1/4 miles with no water pump? that is ridicules... and tire size, o.e diameter is 24.865 inchs and his 205-40r16 have 22.430 inchs in dia. I admit it will get you off the line faster but you are actually driving 10%greater distance than the actual 1/4 mile. And finally, I also have the k&n,ram air , add dual exhaust , removed head light(for ram air),110 octane gas(15 litres on empty tank),no spare and back seat,ecu and resistor mod, 50/50 lockup, no a/c belt and still can't manage to hit 15.2. I'm triing all the tricks in the book has you can see!! now installing 5 spd tranny.
so either this guy if full of b.s or he mispelled WRX. this is my opinion...
The water pump is driven by the timing belt.
Sorry dident read your post Huck, i dident think there was a second page.
Old 05-28-2004, 10:10 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Laying down the gauntlet...
By the time I'm done with my '96 SVX L, she'll be in the 14's naturally aspirated before I do my 5spd swap. One big factor that solarsvx mentioned earlier in this thread is outside air temp - this can play a HUGE factor!
When I first raced my stock Lightning 2 years ago, my fastest time on a muggy 90* June day at MIR dragway was a 13.99 @ 100.5mph. This spring, on the first day that tracks opened up for the season, I ran my L again in 51* weather and got 2 13.6's and 2 13.7's with trap speeds of ~ 101.5mph.
My awd L model weighs ~100lbs less than the Lsi models (3490lbs w/ 1/2 tank of gas + no driver), but still ~100lbs more than the FWD SVX's. Hopefully in the fall, when temps cool down again, I'll be able to snag that 14sec time slip and get my car on Myxalplyx's Scoobymile! The mods I plan should definitely get me the extra 20-30hp I'll need to dip under the 15sec barrier...
-Chike
2006 Steel Gray WRX TR (sold)
Old 05-29-2004, 11:34 AM
starsh0t starsh0t is offline
Send a message via AIM to starsh0t Send a message via Yahoo to starsh0t
this is very possible. stop *****ing.
