Old 12-31-2004, 11:25 AM
I like that idea. I use a light bulb to charge/discharge my capacitor any time I have to disconnect the battery.
Old 01-23-2005, 04:24 PM
rob_4187's Avatar
rob_4187 rob_4187 is offline
You're mine!!
Send a message via AIM to rob_4187
Here we go again
Ok, so thismorning i drove my car and when i parked it i was hearing a clicking sound from the trunk and my seatbelt was going back very slowly in small steps. I didnt have time to mess with it and when i got back the battery was dead. I had a friend jump me and it was working and when i drove to work it started doing it again so i unplugged the battery. I plugged it back in and it started right up. I got home and it was doing it again so i decided to get your guy's opinons. Anything?
Teal 92 SVX LS L with 103k
Engine: Stage 1, 3 in filter with heat sheild, underdrive pulley, NOS fogger system (75 shot)to be installed soon Sound:1 10" infinity with 230 continuous watt Dual amp (we have small trunks)
Old 01-23-2005, 06:00 PM
Well, that sounds like a faulty circuit or relay on the auto seatbelt.
Bring it to an auto electrician and explain what happened. he should be able to sort it fairly quickly.
Old 01-23-2005, 06:26 PM
rob_4187's Avatar
You're mine!!
Thats what im thinking i'll have to do. It's done it before but it usually stops if i turn the battery on and open and close the door a couple times.
Old 10-23-2005, 06:35 PM
michael's Avatar
michael michael is offline
What Potholes ???
Battery Dying?
Does anyone know which fuse supplies power to the sun visor's vanity light?
I put a test light between the negative battery terminal and the body to test for a voltage leak. It shows a pulsing light that goes away after a few seconds. I pulled every fuse and relay from both boxes asside from the airbag fuses, with no change. I also tested any aftermarket equipment. Thanks for any help/advise.
Wanted: Steering Wheel
