Transmission Oil cooler help please?
I want to install an external Transmission Cooler on the 1995 L I just acquired. Where can I purchase one and is that something you would traditionally ask a dealer to install for you?
Many are buying their B&M coolers from www.summitracing.com.
A dealer, generally, will not put an aftermarket cooler in -- just depends on what type of relationship you have with your dealer. For sure, though, a reputable transmission shop will be happy to install it or, if you know of a good independent shop. It is relatively easy to install (though I didn't do mine myself -- I would've, if the shop hadn't done it the first time they rebuilt my tranny).
There are quite a few options to select from on SummitRacing.com
Is there a particular model # that I should be looking for? What about accessory parts like mounting brackets? |
I got an answer from SummitRacing that they are universal and it only depends on the available space you have to mount it.
So...for my next question: What size should I get??? |
I, personally, have the 14,500 lb GVW Tru Cool (I'd recommend this, or even lesser-- maybe 11,000 lb -- GVW if you live in a cold climate -- remember, the tranny don't shift to 4th until the fluid has reached at least 50 degrees F). http://www.bulkparts.com/MM001.ASP?pageno=1183
Excellent...thanks for the help!!!!
