Spare connector - what is it for?.
OK - so took out the glove box on my RHD 95 OBD1 (to change over the cruise control module - CC has not worked for over 10 years).
Only to find a spare connector, it is 8-way / 3-pin - looks like it should connect to something that is missing on the metal bracket below it ?. Any guesses as to what it might be for?.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: Spare connector - what is it for?.
so I guess I am the only person with this spare connector?
That looks like the connector for the door lock timer module.
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
thanks for that - will look into it today, I have a couple of them here, is it part of the security system?.
OK so it looks like the Timer for Door Lock (what ever that is ?).
The module I have is from USA and uses all 8 pins, the mating part on my car only has 3 wires?. Will try and reverse engineer the PCB from module later on tomorrow. Can someone in NZ or AUS please check under and to the left of the glove box to see a) how many wires comes from their connector and b) what the module p/n is. TIA
Yes finally figured out what I actually have -
1x Center console, door lock/unlock switch 1x Under dash door lock timer and I have found the circuit to wire them together ----- all I am still requiring is the switch mating connector.....anyone wanting to get around the U Pull yards and get me one with a short length of OEM wiring - these came only on 95+.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 10-31-2017 at 03:19 PM. |
Thread Tools | |
Display Modes | Rate This Thread |
